    How To Merge Multiple Gameslist.xml Of Same Console Folder?
    Your recalbox
    merge multiple gameslist.xml same console
    • tdelios
      tdelios last edited by
      Over the last couple of years, I have been keeping backups of the Gameslist.xml file after scraping roms that have come and gone in their respective rom folders due to GB size of the micro SD card.
      Is there an easy way or a tool that will read multiple copies of gameslist.xml files and merge them into one?
        Substring @tdelios last edited by
        @tdelios None that I know of ...
