    Final Fantasy 9 cutscenes stutter
    fantasy cutscenes stutter
    • pegasos123
      pegasos123 last edited by
      Hello everyone, <span style="line-height: 1.5;">Iam having bad stuttering Problems during cutscenes in final Fantasy 9. </span> <span style="line-height: 1.5;">Is there a way to present this? </span>
      • seic
        seic last edited by
        Pi 1 or Pi 2? Maybe 3.3.0 brings some changes in performance. But you should play with the idea of overlocking your Pi. I play the german pal version of ff9 on my pi 2 and it's runs very smooth.
        • pegasos123
          I am on pi 2. Can you Post your overclock settings? Do you use a cooler?
          • seic
            seic last edited by
            Sure I can and no my RPi don't use any active/passive cooler. Under load on these hot days (in room temp 30°C) the max temp I have seen with closed case was 67 °C. http://haydenjames.io/raspberry-pi-2-overclock/ < a good beginner article about overclocking  the RPi2 ---- arm_freq=1100 core_freq=500 sdram_freq=480 over_voltage=4 temp_limit=75
