    Solved Games don't start when using Sega Master System Control Pad 3020
    GamePad/GPIO/USB encoder
    dont start sega master control
    • sinon
      sinon last edited by
      Hi there,
      I successfully converted a Sega Master System Control Pad 3020 to USB with this circuit: http://www.raphnet-tech.com/products/nes2usb/
      The gamepad is detected by Recalbox and I am able to configure the directional pad and the two buttons. The "1 / Start" button as "B" and the "2" button as "A", but I've also tried other settings.
      Unfortunately if I start ROMS (not only for SMS) the screen goes black and returns to menu after a few seconds.
      With Xbox Controller 360 and NES30 Pad everything works fine.
      I suppose the problem is related with the lack of a configured Start or / and Select button, but I'm not sure about it.
      Is there anything I can do to get / provide more information that helps to solve the problem?
      PS: I've got it running with Lakka, but I prefer Recalbox.
      • sinon
        My assumption regarding lack of Start / Select button in controller configuration was right.
        I solved the problem by simply adding fake entries to /recalbox/share/system/.emulationstation/es_input.cfg
