    I tried to compile Recalbox,but......................?
    tried compile
    3144
    • tlanks
      tlanks last edited by
      I tried to compile Recalbox,when i finished,it looks like all good,But,when installed,this screen showed ,what was is?
      • tlanks
        HOW TO FIX IT ?
          Hi, this is not really a problem. These files have not been modified on github since the 3.2.8 version, so you have a false version information. https://github.com/digitalLumberjack/recalbox-buildroot/blob/unified/board/recalbox/fsoverlay/recalbox/recalbox.version https://github.com/digitalLumberjack/recalbox-buildroot/blob/unified/board/recalbox/fsoverlay/recalbox/recalbox.msg But if you have compiled recalbox from the github, you have the last version.
          • tlanks
            but ,Had i really b*mped to 3.18.8 kernel ? how to fix it ? change recalbox.version to 3.2.11 ? or keep it still ?
              this information is just used by ES to display the version number. But you are not really in 3.2.8. If you build from the github, you are in 3.3.0 alpha and your kernel must be 3.19.3-v7 (uname -r in ssh to check). You have news systems from alpha, new configgen etc... You can update online from ES to the last alpha version.
              • tlanks
                that is to say i need to update kernel to 3.19.3-v7 ,Am i right ?
                • tlanks
                  how ?
                  • tlanks
                    my linux package name is linux-108e489c19d92800dfc7f04ec93f57468ffff751.tar.gz is it right ? i take this on https://github.com/digitalLumberjack/recalbox-buildroot/commit/a74a9e3d93edacc7f465a03ac07bc8e7e47b8d2b
