    gamepad ps3 dreamcast
    GamePad/GPIO/USB encoder
    8542
    • Edvis
      Edvis last edited by
      Please tell me how to solve the problem. gamepad ps3 in all emulators is working fine, and in the dreamcast the left joystick when pressed to the left is triggered as to the right0_1509447570788_Screenshot_49.png
      Substring abunille 2 Replies Last reply Reply Quote 0
        Substring @Edvis last edited by
        @edvis @abunille has the same problem, haven't had time yet to investigate on this
        Edvis 2 Replies Last reply Reply Quote 0
        • abunille
          abunille @Edvis last edited by
          @edvis
          Hi,
          Odroid?
          Edvis 1 Reply Last reply Reply Quote 0
          • Edvis
            Edvis @abunille last edited by
            @abunille Raspberry Pi 3 b
            • Edvis
              Edvis @Substring last edited by
              @substring I really hope that you will find a solution, thanks
              • abunille
                @edvis
                Hi,
                do you use internal bt or dongle?
                Which driver (bluez, shanwan, official)?
                I tested on PI3 with internal bt.
                official and shanwan makes the issue how i see.
                With "bluez" it works for me.
                • Edvis
                  @abunille Hi, I use the internal bluetooth, official driver. the left button does not work correctly. and bluetooth and wire
                  on shanwan and bluez gamepad on bluetooth does not work, but with the wire working, the button to the left works correctly.
                  • abunille
                    @edvis
                    Mmmhh,
                    "Genuine" DualShock 3 Controller?
                    I have tested with that one.
                    I have only changed the driver and reboot (no reset, no repairing).
                    • Edvis
                      @abunille bought on aliexpress I think it's not genuine0_1509544857497_CQnxzTeZhas.jpg
                      • ishim7924
                        ishim7924 last edited by
                        i have the same problem, i changed the controllerP1 file on RECALBOX\share\system\configs\reicast , but it doesn't fix it. I have two asian copies of dualshock 3 , and i use a dongle, official driver.
                        • Edvis
                          @substring hello, did you find a solution to this problem?
                            @edvis i have found where i should maie some changes, but i'm busy with other matters for now
                            Edvis 3 Replies Last reply Reply Quote 1
                            • Edvis
                              @substring 😃
                              • Edvis
                                @substring Hello, tell me please in which update this will be fixed?
                                  @edvis how can I know ?
                                  • ishim7924
                                    i don't know if i said it before, but the NES30Pro doesn't have this problem, it works fine; maybe the problem appears just with a ps3 gamepad
                                    • Edvis
                                      Edvis @ishim7924 last edited by
                                      @ishim7924 some people with Wii U Pro controllers also have such problems
                                      • Edvis
                                        @ishim7924 tell me, if I buy one NES30Pro controller, can it be used in conjunction with the ps3 controller?
                                        ishim7924 1 Reply Last reply Reply Quote 0
                                        • ishim7924
                                          ishim7924 @Edvis last edited by
                                          @edvis i have used ps3 controllers and NES30Pro at the same time, but only with 64 emulator, Neogeo and SNES; but when i use the two at the same time in Neogeo, neither of the two work, and i can't configure the NES30Pro to retroarch, i don't know if you have the same problem
                                          • Edvis
                                            @ishim7924 thanks. I did not buy nes30pro yet
