    Turrican II under Dosbox
    turrican under dosbox
    3344
    • Dragu
      Dragu Banned last edited by OyyoDams
      So, I have it working but some datas are weird concerning installation.
      It was the only Turrican under DOS. (1995).
      First there is a subdirectory /cfg in the files with inside English.lng and Turrican.cfg.
      You must copy /cfg/English.cfg to the root, without setup is impossible.
      Second, create an empty file Turrican.cfg in the root.
      When the game is started, he will enter everytime with display of Setup.
      One of the weird thing, you must just know it.
      In Dosbox.bat you must set an environnement variable before you call the game :
      SET T2DIR=.
      T2.EXE
      I have still an unresolved problem, no scrap file.
      Even as you have in thegamesdb.net a plain list of, but with no dos variant.
      But the same game exist, just under amiga : Turrican II : The final fight
      Is there a way to scrap Amiga descriptions (as example) under Dosbox ?
        voljega Banned @Dragu last edited by
        @dragu well I can only tell you that all three Turricans work perfectly fine on Amiga and Recalbox 😉
        • Cthulhus
          Cthulhus last edited by
          Thanks Dragu !
          @voljega Amiga ? Added yourself ? I just added the Amiga CD32, so you mean that one ?
          C'était mieux avant :-)
          • Dragu
            @voljega
            I have still the march version 4.1u in use because of the bug with hifiberry sound. And in this version, no Amiga rom place.
            But I think the screen resolution is lower as the PC version. Do you have a screenshot from gamestart, like mine upper, to compare ? 🙂
            Concerning the scraper, some things like limitation on hardware, even with individual search, I cannot understand ?
              voljega Banned @Cthulhus last edited by
              @cthulhus see my signature 😉
              Cthulhus 1 Reply Last reply Reply Quote 0
              • Cthulhus
                Cthulhus @voljega last edited by
                @voljega said in Turrican II under Dosbox:
                humm sweety 🙂
                • Dragu
                  Ok, I gave it a try.
                  But honestly, the one and only DOS version of Turrican II has a far better resolution as the Amiga CD32 version.
                  And far more easy to configurate. So if I put quality over quantity, I am on Dosbox with this one. 🙂
                  Amiga screenshot to compare
