    XBOX 360 Controller not working
    GamePad/GPIO/USB encoder
    xbox 360
    • peter-lustig
      peter-lustig last edited by
      Hello, i connected my xbox controller to the pi via the wireless receiver. But it's not recognized. I tried multiple times to pair but there is not response. I dont have a keyboard.
      [    0.000000] Booting Linux on physical CPU 0xf00 [    0.000000] Initializing cgroup subsys cpu [    0.000000] Initializing cgroup subsys cpuacct [    0.000000] Linux version 3.19.2-v7 (matthieu@sd-69673) (gcc version 4.9.2 (Buildroot 2015.05-git-g2a969e7-dirty) ) #1 SMP PREEMPT Tue Mar 24 00:17:48 CET 2015 [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [    0.000000] Machine: BCM2709 [    0.000000] cma: Reserved 8 MiB at 0x1e800000 [    0.000000] Memory policy: Data cache writealloc [    0.000000] On node 0 totalpages: 126976 [    0.000000] free_area_init_node: node 0, pgdat 80ac2280, node_mem_map 9e396000 [    0.000000]   Normal zone: 1116 pages used for memmap [    0.000000]   Normal zone: 0 pages reserved [    0.000000]   Normal zone: 126976 pages, LIFO batch:31 [    0.000000] [bcm2709_smp_init_cpus] enter (8640->f3003010) [    0.000000] [bcm2709_smp_init_cpus] ncores=4 [    0.000000] PERCPU: Embedded 11 pages/cpu @9e366000 s12672 r8192 d24192 u45056 [    0.000000] pcpu-alloc: s12672 r8192 d24192 u45056 alloc=11*4096 [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 125860 [    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1776 bcm2708_fb.fbheight=952 bcm2709.boardrev=0xa01041 bcm2709.serial=0x4c8be109 smsc95xx.macaddr=B8:27:EB:8B:E1:09 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty3 loglevel=3 elevator=deadline vt.global_cursor_default=0 logo.nologo root=/dev/mmcblk0p6 rootwait [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [    0.000000] Memory: 482784K/507904K available (7904K kernel code, 451K rwdata, 2192K rodata, 484K init, 777K bss, 16928K reserved, 8192K cma-reserved) [    0.000000] Virtual kernel memory layout: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB) [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB) [    0.000000]     vmalloc : 0x9f800000 - 0xff000000   (1528 MB) [    0.000000]     lowmem  : 0x80000000 - 0x9f000000   ( 496 MB) [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB) [    0.000000]       .text : 0x80008000 - 0x809e44c8   (10098 kB) [    0.000000]       .init : 0x809e5000 - 0x80a5e000   ( 484 kB) [    0.000000]       .data : 0x80a5e000 - 0x80acec74   ( 452 kB) [    0.000000]        .bss : 0x80acec74 - 0x80b91164   ( 778 kB) [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [    0.000000] Preemptible hierarchical RCU implementation. [    0.000000] NR_IRQS:608 [    0.000000] Architected cp15 timer(s) running at 19.20MHz (virt). [    0.000015] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns [    0.000037] Switching to timer-based delay loop, resolution 52ns [    0.000317] Console: colour dummy device 80x30 [    0.000542] console [tty3] enabled [    0.000574] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000) [    0.000601] pid_max: default: 32768 minimum: 301 [    0.001026] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [    0.001051] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [    0.002352] Initializing cgroup subsys memory [    0.002402] Initializing cgroup subsys devices [    0.002431] Initializing cgroup subsys freezer [    0.002473] Initializing cgroup subsys blkio [    0.002568] CPU: Testing write buffer coherency: ok [    0.002654] ftrace: allocating 25269 entries in 75 pages [    0.064519] missing device node for CPU 0 [    0.064561] missing device node for CPU 1 [    0.064573] missing device node for CPU 2 [    0.064584] missing device node for CPU 3 [    0.064606] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [    0.064623] [bcm2709_smp_prepare_cpus] enter [    0.064771] Setting up static identity map for 0x72aa00 - 0x72aa58 [    0.124540] [bcm2709_boot_secondary] cpu:1 started (0) 18 [    0.124925] [bcm2709_secondary_init] enter cpu:1 [    0.124986] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [    0.144507] [bcm2709_boot_secondary] cpu:2 started (0) 16 [    0.144824] [bcm2709_secondary_init] enter cpu:2 [    0.144861] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [    0.164586] [bcm2709_boot_secondary] cpu:3 started (0) 18 [    0.164830] [bcm2709_secondary_init] enter cpu:3 [    0.164868] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [    0.164968] Brought up 4 CPUs [    0.164996] SMP: Total of 4 processors activated (153.60 BogoMIPS). [    0.165008] CPU: All CPU(s) started in SVC mode. [    0.166068] devtmpfs: initialized [    0.186133] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [    0.187611] pinctrl core: initialized pinctrl subsystem [    0.188169] regulator-dummy: no parameters [    0.188850] NET: Registered protocol family 16 [    0.194721] DMA: preallocated 4096 KiB pool for atomic coherent allocations [    0.224362] cpuidle: using governor ladder [    0.254391] cpuidle: using governor menu [    0.254964] bcm2709.uart_clock = 3000000 [    0.255007] of_platform_populate failed: -22 [    0.257478] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [    0.257494] hw-breakpoint: maximum watchpoint size is 8 bytes. [    0.257535] mailbox: Broadcom VideoCore Mailbox driver [    0.257650] bcm2708_vcio: mailbox at f300b880 [    0.258019] bcm_power: Broadcom power driver [    0.258036] bcm_power_open() -> 0 [    0.258047] bcm_power_request(0, 😎 [    0.758713] bcm_mailbox_read -> 00000080, 0 [    0.758726] bcm_power_request -> 0 [    0.758863] Serial: AMBA PL011 UART driver [    0.759002] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3 [    0.837485] SCSI subsystem initialized [    0.837951] usbcore: registered new interface driver usbfs [    0.838064] usbcore: registered new interface driver hub [    0.838216] usbcore: registered new device driver usb [    0.838889] Advanced Linux Sound Architecture Driver Initialized. [    0.839823] Bluetooth: Core ver 2.20 [    0.839889] NET: Registered protocol family 31 [    0.839901] Bluetooth: HCI device and connection manager initialized [    0.839934] Bluetooth: HCI socket layer initialized [    0.839955] Bluetooth: L2CAP socket layer initialized [    0.840046] Bluetooth: SCO socket layer initialized [    0.840659] cfg80211: Calling CRDA to update world regulatory domain [    0.841919] Switched to clocksource arch_sys_counter [    0.882168] FS-Cache: Loaded [    0.882544] CacheFiles: Loaded [    0.897985] NET: Registered protocol family 2 [    0.899128] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [    0.899218] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [    0.899324] TCP: Hash tables configured (established 4096 bind 4096) [    0.899404] TCP: reno registered [    0.899427] UDP hash table entries: 256 (order: 1, 8192 bytes) [    0.899469] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [    0.899761] NET: Registered protocol family 1 [    0.900373] RPC: Registered named UNIX socket transport module. [    0.900393] RPC: Registered udp transport module. [    0.900404] RPC: Registered tcp transport module. [    0.900416] RPC: Registered tcp NFSv4.1 backchannel transport module. [    0.901323] bcm2708_dma: DMA manager at f3007000 [    0.901465] bcm2708_gpio: bcm2708_gpio_probe 80a8a568 [    0.902284] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB) [    0.904453] futex hash table entries: 1024 (order: 4, 65536 bytes) [    0.904684] audit: initializing netlink subsys (disabled) [    0.904748] audit: type=2000 audit(0.869:1): initialized [    0.922840] DLM installed [    0.925624] FS-Cache: Netfs 'nfs' registered for caching [    0.926638] NFS: Registering the id_resolver key type [    0.926710] Key type id_resolver registered [    0.926723] Key type id_legacy registered [    0.927777] ntfs: driver 2.1.31 [Flags: R/W]. [    0.928692] fuse init (API version 7.23) [    0.932278] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) [    0.932472] io scheduler noop registered [    0.932500] io scheduler deadline registered (default) [    0.932883] io scheduler cfq registered [    0.934544] BCM2708FB: allocated DMA memory dec00000 [    0.934591] BCM2708FB: allocated DMA channel 0 @ f3007000 [    0.962554] Console: switching to colour frame buffer device 222x59 [    0.981119] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver [    0.981656] uart-pl011 dev:f1: no DMA platform data [    0.982334] vc-cma: Videocore CMA driver [    0.982350] vc-cma: vc_cma_base      = 0x00000000 [    0.982362] vc-cma: vc_cma_size      = 0x00000000 (0 MiB) [    0.982374] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB) [    0.995780] brd: module loaded [    1.002633] loop: module loaded [    1.003016] vchiq: vchiq_init_state: slot_zero = 0x9e800000, is_master = 0 [    1.003898] Loading iSCSI transport class v2.0-870. [    1.004743] usbcore: registered new interface driver cdc_ether [    1.004888] usbcore: registered new interface driver smsc95xx [    1.004959] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [    1.004981] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [    1.005037] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [    1.205395] Core Release: 2.80a [    1.205415] Setting default values for core params [    1.205464] Finished setting default values for core params [    1.405890] Using Buffer DMA mode [    1.405907] Periodic Transfer Interrupt Enhancement - disabled [    1.405918] Multiprocessor Interrupt Enhancement - disabled [    1.405930] OTG VER PARAM: 0, OTG VER FLAG: 0 [    1.405949] Dedicated Tx FIFOs mode [    1.406397] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0x9ec14000 dma = 0xdec14000 len=9024 [    1.406437] FIQ FSM acceleration enabled for : [    1.406437] Non-periodic Split Transactions [    1.406437] Periodic Split Transactions [    1.406437] High-Speed Isochronous Endpoints [    1.406483] dwc_otg: Microframe scheduler enabled [    1.406573] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80476b74 [    1.406595] WARN::hcd_init_fiq:413: FIQ ASM at 0x80476ee4 length 36 [    1.406617] WARN::hcd_init_fiq:438: MPHI regs_base at 0x9f80a000 [    1.406647] dwc_otg bcm2708_usb: DWC OTG Controller [    1.406699] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1 [    1.406752] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000 [    1.406807] Init: Port Power? op_state=1 [    1.406818] Init: Power Port (0) [    1.407133] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [    1.407153] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.407170] usb usb1: Product: DWC OTG Controller [    1.407186] usb usb1: Manufacturer: Linux 3.19.2-v7 dwc_otg_hcd [    1.407203] usb usb1: SerialNumber: bcm2708_usb [    1.408341] hub 1-0:1.0: USB hub found [    1.408408] hub 1-0:1.0: 1 port detected [    1.409128] dwc_otg: FIQ enabled [    1.409145] dwc_otg: NAK holdoff enabled [    1.409157] dwc_otg: FIQ split-transaction FSM enabled [    1.409201] Module dwc_common_port init [    1.409768] mousedev: PS/2 mouse device common for all mice [    1.410987] Bluetooth: Virtual HCI driver ver 1.5 [    1.411218] Bluetooth: HCI UART driver ver 2.2 [    1.411235] Bluetooth: HCI H4 protocol initialized [    1.411246] Bluetooth: HCI BCSP protocol initialized [    1.411258] Bluetooth: HCILL protocol initialized [    1.411268] Bluetooth: HCIATH3K protocol initialized [    1.411279] Bluetooth: HCI Three-wire UART (H5) protocol initialized [    1.411415] usbcore: registered new interface driver bcm203x [    1.411540] usbcore: registered new interface driver bpa10x [    1.411663] usbcore: registered new interface driver bfusb [    1.411802] usbcore: registered new interface driver btusb [    1.411826] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [    1.412106] usbcore: registered new interface driver ath3k [    1.412436] bcm2835-cpufreq: min=600000 max=900000 [    1.425524] Driver 'mmcblk' needs updating - please use bus_type methods [    1.425583] sdhci: Secure Digital Host Controller Interface driver [    1.425592] sdhci: Copyright(c) Pierre Ossman [    1.425736] DMA channels allocated for the MMC driver [    1.462025] Load BCM2835 MMC driver [    1.462161] sdhci-pltfm: SDHCI platform and OF driver helper [    1.464538] ledtrig-cpu: registered to indicate activity on CPUs [    1.464659] hidraw: raw HID events driver (C) Jiri Kosina [    1.469277] usbcore: registered new interface driver usbhid [    1.469287] usbhid: USB HID core driver [    1.469768] TCP: cubic registered [    1.469785] Initializing XFRM netlink socket [    1.475119] NET: Registered protocol family 10 [    1.479576] sit: IPv6 over IPv4 tunneling driver [    1.480437] NET: Registered protocol family 17 [    1.480622] Bluetooth: RFCOMM TTY layer initialized [    1.480652] Bluetooth: RFCOMM socket layer initialized [    1.480684] Bluetooth: RFCOMM ver 1.11 [    1.480708] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [    1.480723] Bluetooth: HIDP socket layer initialized [    1.481311] sctp: Hash tables configured (established 16384 bind 16384) [    1.481845] Key type dns_resolver registered [    1.482322] Registering SWP/SWPB emulation handler [    1.483118] registered taskstats version 1 [    1.483315] vc-sm: Videocore shared memory driver [    1.483331] [vc_sm_connected_init]: start [    1.483889] [vc_sm_connected_init]: end - returning 0 [    1.486136] ALSA device list: [    1.486150]   #0: bcm2835 ALSA [    1.486799] Waiting for root device /dev/mmcblk0p6... [    1.499269] mmc0: host does not support reading read-only switch, assuming write-enable [    1.501432] mmc0: new high speed SDHC card at address 0002 [    1.501894] mmcblk0: mmc0:0002 00000 7.41 GiB [    1.507163]  mmcblk0: p1 p2 < p5 p6 p7 > p3 [    1.593112] EXT4-fs (mmcblk0p6): couldn't mount as ext3 due to feature incompatibilities [    1.594117] EXT4-fs (mmcblk0p6): couldn't mount as ext2 due to feature incompatibilities [    1.602051] Indeed it is in host mode hprt0 = 00021501 [    1.782037] usb 1-1: new high-speed USB device number 2 using dwc_otg [    1.782181] Indeed it is in host mode hprt0 = 00001101 [    1.982234] usb 1-1: New USB device found, idVendor=0424, idProduct=9514 [    1.982251] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [    1.983073] hub 1-1:1.0: USB hub found [    1.983172] hub 1-1:1.0: 5 ports detected [    2.262031] usb 1-1.1: new high-speed USB device number 3 using dwc_otg [    2.362265] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00 [    2.362286] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [    2.365258] smsc95xx v1.0.4 [    2.426321] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:8b:e1:09 [    2.502063] usb 1-1.4: new full-speed USB device number 4 using dwc_otg [    2.612296] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b [    2.612318] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    2.612334] usb 1-1.4: Product: USB Receiver [    2.612351] usb 1-1.4: Manufacturer: Logitech [    2.702036] usb 1-1.5: new full-speed USB device number 5 using dwc_otg [    2.814223] usb 1-1.5: New USB device found, idVendor=045e, idProduct=0291 [    2.814245] usb 1-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [    3.615331] EXT4-fs (mmcblk0p6): recovery complete [    3.697827] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null) [    3.697908] VFS: Mounted root (ext4 filesystem) on device 179:6. [    3.699209] devtmpfs: mounted [    3.700020] Freeing unused kernel memory: 484K (809e5000 - 80a5e000) [    3.856428] EXT4-fs (mmcblk0p6): re-mounted. Opts: data=ordered [    3.889212] FAT-fs (mmcblk0p7): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [    3.894307] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [    4.320576] udevd[91]: starting version 2.1.1 [    4.348862] random: udevd urandom read with 81 bits of entropy available [    5.283843] input: Xbox 360 Wireless Receiver (XBOX) as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.0/input/input0 [    5.285391] input: Xbox 360 Wireless Receiver (XBOX) as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.2/input/input1 [    5.286693] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-bcm2708_usb-1.4/input2 [    5.287342] input: Xbox 360 Wireless Receiver (XBOX) as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.4/input/input2 [    5.288896] input: Xbox 360 Wireless Receiver (XBOX) as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.6/input/input3 [    5.290074] usbcore: registered new interface driver xpad [    5.665109] input: Logitech M315/M235 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:4009.0004/input/input4 [    5.665877] logitech-hidpp-device 0003:046D:4009.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech M315/M235] on usb-bcm2708_usb-1.4:1 [    5.833745] random: nonblocking pool is initialized [   12.184302] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [   12.184509] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [   13.603719] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [   13.604823] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
