    share partition not full size
    share partition full size
    • nakotic007
      nakotic007 last edited by
      dear friends,
      I use a 64GB SDXC card that I already formattet to fat32. NOOBS says full 64GB are available and installation works great. The problem now is, that RECALBOX says that my internal space is only 25GB. It propably makes sense in case RECALBOX just detects 32GB minus installation of RECALBOX and RASPBIAN.
      I want to use all 64GB, even GPARTED says it's 64GB, but divided in 30GB root partition and only 25GB for share partition.. how could I resize that major space is available for the space partition?
      BRs
      NeeeeB 1 Reply Last reply Reply Quote 0
      • NeeeeB
        NeeeeB @nakotic007 last edited by
        @nakotic007
        Well, with GParted, shrink the root partition (not too much of course) and extend the share partition.
        You might want to wait for someone to tell you the minimum required size for the root partition though.
        Vieux geek ^^
        nakotic007 1 Reply Last reply Reply Quote 1
        • nakotic007
          nakotic007 @NeeeeB last edited by
          @neeeeb that would be cool to know how small root may be 🙂
          • Javier Sandoval
            Javier Sandoval last edited by
            boot its 64mb, recalbox 2gb,the rest is share
            • nakotic007
              nakotic007 @Javier Sandoval last edited by
              @javier-sandoval thanks mate, I'll give it a try
