    Régler manuellement les deadzones
    régler manuellement deadzones
    7
    23
    7861
      rockaddicted @Substring last edited by
      @substring said in Régler manuellement les deadzones:
      the joystick API is outdated, clearly. I think only AplleII and scummvm use SDL 1 for now. Scummvm will switch to SDL2 on the next b*mp, leaving only AppleII on SDL1 (if my memory is not failing)
      scummvm is already using sdl2 since last b*mp.
      ScummVM-RASPBERRYPI README
      Notes
      This version of ScummVM uses SDL2 hardware accelerated graphics, be it
      plain SDL2 which in turn uses dispmanx/gles2 or by using gles1 via an
      SDL2-configured GLES1 context.
        voljega Banned @Substring last edited by
        can we patch dosbox to add a custom deadzone
        yes : http://www.vogons.org/viewtopic.php?t=24832
        but as redm stated it might be better to handle that on the OS part maybe ?
        • ironic
          ironic last edited by
          Hi.
          Really happy to see some guys working on deadzone.
          Sorry for not releasing this piece of code, i have no time to rewrite/release it. It can be used to try joystick on jsX. Later, i think i'll make it better.
          Get it here but it was written for 450*270 screen resolution.
          It'll be tiny on LCD resolution. (edit line 123 for font path).
          Python 2.7 (Pygame) use SDL1 too.
          100.1k
