    [Résolu]Scraper screenshots
    bluetooh
    • loopingstar
      loopingstar last edited by
      Bonjour, Bravo et merci à l'auteur de recalbox !!! Est-il possible d'avoir les snapshots de jeu plutôt que les jaquettes, dans le scraper ?
      • reivaax
        reivaax last edited by
        Bonjour Loopingstar, Oui c'est possible si tu scrapp via ton pc https://github.com/digitalLumberjack/recalbox-os/wiki/Scrapez-vos-jeux-avec-votre-PC-(FR). Tu peux définir le type de visuel que tu souhaite scrapper et les priorités...
        • loopingstar
          Merci pour cette réponse Reivaax 🙂 J'ai utilisé ce scraper pour toutes mes roms, j'avais pas capté que le scraper avait pleins de paramètres. Les voici : Usage of scraper: -add_not_found=false: If true, add roms that are not found as an empty gamelist entry. -append=false: If the gamelist file already exist skip files that are already listed and only append new files. -download_images=true: If false, don't download any images, instead see if the expected file is stored locally already. -gdb_img="b": Comma seperated order to prefer images, s=snapshot, b=boxart, f=fanart, a=banner, l=logo. -hash_file="": The file containing hash information. -image_dir="images": The directory to place downloaded images to locally. -image_path="images": The path to use for images in gamelist.xml. -image_suffix="-image": The suffix added after rom name when creating image files. -img_format="jpg": jpg or png, the format to write the images. -mame=false: If true we want to run in MAME mode. -mame_img="s,t,m,c": Comma seperated order to prefer images, s=snap, t=title, m=marquee, c=cabniet. -max_width=400: The max width of images. Larger images will be resized. -nested_img_dir=false: Use a nested img directory structure that matches rom structure. -no_thumb=false: Don't add thumbnails to the gamelist. -output_file="gamelist.xml": The XML file to output to. -retries=2: The number of times to retry a rom on an error. -rom_dir=".": The directory containing the roms file to process. -rom_path=".": The path to use for roms in gamelist.xml. -scrape_all=false: If true, scrape all systems listed in es_systems.cfg. All dir/path flags will be ignored. -skip_check=false: Skip the check if thegamesdb.net is up. -start_pprof=false: If true, start the pprof service used to profile the application. -strip_unicode=true: If true, remove all non-ascii characters. -thumb_only=false: Download the thumbnail for both the image and thumb (faster). -thumb_suffix="-thumb": The suffix added after rom name when creating thumb files. -use_cache=false: Use sselph backup of thegamesdb. -use_filename=false: If true, use the filename minus the extension as the game title in xml. -use_gdb=true: Use the hash.csv and theGamesDB metadata. -use_nointro_name=true: Use the name in the No-Intro DB instead of the one inthe GDB. -use_ovgdb=false: Use the OpenVGDB if the hash isn't in hash.csv. -version=false: Print the release version and exit. -workers=1: The number of worker threads used to process roms. Exemple pour récupérer les logos des jeux Sega Master System en PNG : scraper.exe -image_path="~/.emulationstation/downloaded_images/sms" -no_thumb=true -max_width=375 -gdb_img="l" -img_format="png" -image_suffix="-logo" -workers=4 Exemple pour récupérer les snapshots en JPG des jeux Sega Master System : scraper.exe -image_path="~/.emulationstation/downloaded_images/sms" -no_thumb=true -max_width=375 -gdb_img="s" -image_suffix="-snapshot" -workers=4 Merci
          • reivaax
            Tu sais ce qui serait vraiment top ! C'est que tu ajoute ces informations là sur le wiki pour que le prochain qui se pause la question est toutes ces informations ! :D. https://github.com/digitalLumberjack/recalbox-os/wiki/Scrapez-vos-jeux-avec-votre-PC-(FR) https://github.com/digitalLumberjack/recalbox-os/wiki/Scrape-your-games-with-your-PC-(EN)   Ne perdez pas de vue que le wiki est avant toute chose écrit par n'importe lequel d'entre nous et qu'a partir du moment ou tu as un compte github, tu peux éditer, compléter le wiki en toute liberté sans droits spécifiques ! :). Donc n'hésitez pas à vous lancer ! :).   Bonne journée
            • loopingstar
              D'accord, dès que je peux, je me créée un compte Github. Moi je suis sur Bitbucket lol
