    Solved How to insert mapper 63 in nes emulator?
    Your recalbox
    insert mapper nes
    • flaviocaste
      flaviocaste last edited by
      Hello everyone, I'm using the unstable version of the recalbox in PI3, I need to emulate an NES game, but it needs mapper 63 to work, is there a way to make it work?
      Thanks.
        did you try the different nes cores available ?
        select on your game, then emulator=libretro / core=coreNAme (test the different ones).
        • flaviocaste
          I'm using version 4.1.0 Rpi3, I changed the core and it worked perfectly. Thank you.
