    Solved Do system images support PNG ?
    Themes & Interface
    png
    • maximus37
      maximus37 last edited by
      I noticed for themes that the system images are all SVG format, which I understand because it's a vector image. But are PNG's supported?
      DAM 1 Reply Last reply Reply Quote 0
      • DAM
        DAM @maximus37 last edited by
        @maximus37 , yes the system suport png files, but you need edited the .xml files´s themes for a background for exemple.
        • maximus37
          @DAM Great! thanks! 🙂
            voljega Banned @maximus37 last edited by voljega
            @maximus37 but be aware that using png will likely cause memory problems when too much systems are used (ie with roms in it)
