    PNY 128gb MicroSD
    Your discoveries
    pny 128gb
    • spiwrx
      spiwrx last edited by
      Just formatted a PNY 128gb "Elite microSDXC" card and it seems to work fine. Added to compatibility wiki.
      FWIW, Probably redundant but I do the following to my 64gb & 128gb cards:
      • SDfomatter (Default settings / Quick format)
      • GUIformat (default settings / FAT32 format)
      • follow regular recalbox os install directions
      Hope thats helpful....
      • Nachtgarm
        Nachtgarm last edited by
        Thanks for the info and the addition to the C-list, but have you considered going for something like this: https://www.amazon.de/dp/B00YFI1EBC/ref=cm_sw_em_r_mt_dp_CG6rybBY2GQEV
        instead of using such "big" cards? Check the speed of this little monster 😉
        USB 3.0
        Sequential (Q32T1)
        exFat: 124MB/s read, 48MB/s write
        FAT32: 117MB/s read, 49MB/s write
        NTFS: 135MB/s read, 50MB/s write
        Sequential
        exFat: 145MB/s read, 64MB/s write
        FAT32: 144MB/s read, 63MB/s write
        NTFS: 150MB/s read, 59MB/s write
        4k (Q32T1)
        exFat: 6,2MB/s read, 3MB/s write
        FAT32: 6,1MB/s read, 3MB/s write
        NTFS: 6,1MB/s read, 3MB/s write
        4k
        exFat: 5,1MB/s read, 2,6MB/s write
        FAT32: 5,8MB/s read, 2,9MB/s write
        NTFS: 5,5MB/s read, 2,8MB/s write
        USB 2.0
        Sequential (Q32T1)
        exFat: 41MB/s read, 27MB/s write
        Sequential
        exFat: 40,7MB/s read, 26MB/s write
        4k (Q32T1)
        exFat: 5,1MB/s read, 3MB/s write
        4k
        exFat: 5MB/s read, 2,8MB/s write
