    gpi case 2w sound work but black screen in pulstar 9.2.3
    Your recalbox
    gpicase2w pulstar 9.2.1 pizero
    • jose_alk
      jose_alk last edited by
      Hello.
      I just updated to Recalbox Pulstar 9.2.3 for a Raspberri Pi Zero mounted in a Retroflag GPi Case 2W
      I have to say that until now I was using Recalbox Pulstar 9.1 and everything was working correctly.
      Now after updating I don't see the image.
      You can hear it perfectly but you can't see it. I have also tried to do an installation with the image downloaded from the Recalbox website and the same thing happens, the audio is heard, but the image is not seen.
      If I reinstall Recalbox Pulstar 9.1 everything works correctly, but the update message appears all the time.
      Please can you help me solve the problem.
      Thank you so muchñ
      Defiant 1 Reply Last reply Reply Quote 0
      • Defiant
        Defiant @jose_alk last edited by
        @jose_alk I'm having the exact same problem, only there's no sound either! I have the official raspberry 7'' TFT screen, and it doesn't work on the screen or on HDMI.
