    retroachievements : option in UI to reset cheevos token
    Testers's corner
    option reset cheevos token
    • dma-sc
      dma-sc last edited by
      Hi there,
      I struggled with retroachievements connexion not willing to work today, despite having the correct login/password combination (the message displayed when the game starts says otherwise, so it's quite misleading, but that's a message from retroarch, not recalbox, so not much to do on this I guess).
      The solution was to do this: https://forum.recalbox.com/topic/27469/8-1-retroachievements-not-working-since-the-update-from-8-0-2/4?_=1722762011435
      So to clear the "cheevos_token" value in the "/recalbox/share/system/configs/retroarch/retroarchcustom.cfg" configuration file.
      It would be great to add a recalbox retroachievments settings menu entry to clear this value, like "reset login token".
