    Problème de compilation
    compilation
    • csamain
      csamain last edited by
      Bonjour, Après avoir pas mal cherché sur le forum et sur le net, je n’ai trouvé aucune piste pour passer mon problème de compilation. J’ai installé Ubuntu (from scratch) mais j’ai essayé aussi docker ensuite sudo docker pull recalbox/recalbox-docker-build sudo docker run -v /tmp/recalboxbuild/:/usr/share/recalbox/build/ -t -e ”RECALBOX_ARCH=rpi2” recalbox/recalbox-docker-build mais après plusieurs heure de compilation j’ai toujours l’erreur suivante :
      rpi-firmware c5e131971c323f5658c7c5d4b1dd105d37903a99 Configuring >>> rpi-firmware c5e131971c323f5658c7c5d4b1dd105d37903a99 Building >>> rpi-firmware c5e131971c323f5658c7c5d4b1dd105d37903a99 Installing to target >>> rpi-firmware c5e131971c323f5658c7c5d4b1dd105d37903a99 Installing to images directory /usr/bin/install -D -m 0644 /usr/share/recalbox/build/rb-4.1.X/rpi2/output/build/rpi-firmware-c5e131971c323f5658c7c5d4b1dd105d37903a99/boot/bootcode.bin /usr/share/recalbox/build/rb-4.1.X/rpi2/output/images/rpi-firmware/bootcode.bin /usr/bin/install -D -m 0644 /usr/share/recalbox/build/rb-4.1.X/rpi2/output/build/rpi-firmware-c5e131971c323f5658c7c5d4b1dd105d37903a99/boot/start””.elf /usr/share/recalbox/build/rb-4.1.X/rpi2/output/images/rpi-firmware/start.elf /usr/bin/install -D -m 0644 /usr/share/recalbox/build/rb-4.1.X/rpi2/output/build/rpi-firmware-c5e131971c323f5658c7c5d4b1dd105d37903a99/boot/fixup””.dat /usr/share/recalbox/build/rb-4.1.X/rpi2/output/images/rpi-firmware/fixup.dat /usr/bin/install -D -m 0644 package/rpi-firmware/config.txt /usr/share/recalbox/build/rb-4.1.X/rpi2/output/images/rpi-firmware/config.txt /usr/bin/install -D -m 0644 package/rpi-firmware/cmdline.txt /usr/share/recalbox/build/rb-4.1.X/rpi2/output/images/rpi-firmware/cmdline.txt for ovldtb in /usr/share/recalbox/build/rb-4.1.X/rpi2/output/build/rpi-firmware-c5e131971c323f5658c7c5d4b1dd105d37903a99/boot/overlays/.dtb; do /usr/bin/install -D -m 0644 ${ovldtb} /usr/share/recalbox/build/rb-4.1.X/rpi2/output/images/rpi-firmware/overlays/${ovldtb##/} || exit 1; done /usr/bin/install: cannot stat â/usr/share/recalbox/build/rb-4.1.X/rpi2/output/build/rpi-firmware-c5e131971c323f5658c7c5d4b1dd105d37903a99/boot/overlays/*.dtbâ: No such file or directory package/pkg-generic.mk:266: recipe for target ’/usr/share/recalbox/build/rb-4.1.X/rpi2/output/build/rpi-firmware-c5e131971c323f5658c7c5d4b1dd105d37903a99/.stamp_images_installed’ failed make: *** [/usr/share/recalbox/build/rb-4.1.X/rpi2/output/build/rpi-firmware-c5e131971c323f5658c7c5d4b1dd105d37903a99/.stamp_images_installed] Error 1 vincent@bcpubuntu-PC:~/recalbox/docker2$
      Une idée d'où cela pourrait venir ?
        https://github.com/recalbox/recalbox-buildroot/blob/rb-4.1.X/package/rpi-firmware/rpi-firmware.mk#L26 modififie dans le package .dtb par .dtbo Petite question curieuse, pourquoi te lances tu dans la compilation du bouzin? 😉
