    Shaders : tips, tests and feedback V8.0.2 or higher
    Themes & Interface
    shaders tips tests feedback v8.0.2 higher
      At the request of 🕹 players 🕹 fans of specific renderings and sharp graphic settings, this topic is open and dedicated to ♒ shaders and their settings 🎛
      Do not hesitate to share your renderings, to post screenshots, to name the shaders and to explain your settings. Shaders being resource-intensive, don't forget to describe your configuration (Pi, PC, Odroid...) 💻 , if options have been activated/desactivated (pixel perfect, rewind, etc...) or even the TV/ screen used (especially for RGB Dual) 📺
      It's up to you 😁
      • Pinned by  Scavy Scavy
      100.7k
