    [Recalbox 9] Theme ARTFLIX NX
    Themes & Interface
    theme recalbox 9
    24831
    • fagnerpc
      fagnerpc Theme moderator last edited by M__a__a__x
      Hi guys,
      ARTFLIX NX is a fusion of my ARTFLIX themes with ALEKFULL NX 😊
      With exclusive arts, automatic translation into 4 languages ​​(PT-BR, EN, ES and FR) and support for all systems of the new RECALBOX 8 🙂
      Special thanks to Butch Games for their support in optimizing the logos 👏 👏
      NX
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      • RECALBOX compatible with the update 8 ELECTRON;
      • Compatible with more than 150 systems: all Recalbox systems and collections - including recent ones like LowRes NX.
      DOWNLOAD HERE
      ARCADE ALEKFULL
      Madmeggo Butch Games M__a__a__x 3 Replies Last reply Reply Quote 3
      • Madmeggo
        Madmeggo @fagnerpc last edited by
        @fagnerpc I have yet to try it out on my system, but from what I have seen here and on youtube I think your theme looks great! Great work!
        • Glascoyote 0
          Glascoyote 0 last edited by Glascoyote 0
          Hello
          I can't find the download. I click on the Link in the youTube Video, but as you can see in the Link below I can`t find any download Package of the Theme.
          https://github.com/fagnerpc/ARTFLIX-NX-Recalbox
          Thank You
          Madmeggo 1 Reply Last reply Reply Quote 0
          • Madmeggo
            Madmeggo @Glascoyote 0 last edited by
            @glascoyote-0 You have to click on the green button that says "Code" and then you can click on "download ZIP" on the menu that opens. I couldn't find it at first too.
            Glascoyote 0 1 Reply Last reply Reply Quote 0
            • Glascoyote 0
              Glascoyote 0 @Madmeggo last edited by
              @madmeggo vielen Dank
              • Madmeggo
                @glascoyote-0 kein Ding, gerne 🙂
                • Butch Games
                  Butch Games Theme moderator @fagnerpc last edited by
                  @fagnerpc
                  Bravo! Très joli thème!
                  • M__a__a__x
                    M__a__a__x Global moderator last edited by M__a__a__x
                    Thank you very much.
                    Theme added in wiki
                    Un grand merci à toi.
                    Thème ajouté dans le wiki
                    https://wiki.recalbox.com/fr/tutorials/frontend-customization/add-themes-into-emulationstation
                    Recalboxment votre,
                    M__a__a__x
                    • M__a__a__x
                      M__a__a__x Global moderator @fagnerpc last edited by
                      @fagnerpc
                      Even if it does not integrate the management of flags in the gamelist and the new systems included in 8.1.1 the theme remains compatible.
                      Même si il n'intègre pas la gestion des drapeaux dans les gamelist et les nouveaux systèmes inclus dans la 8.1.1 le thème reste compatible.
                      Recalboxment votre,
                      M__a__a__x
                      • M__a__a__x
                        Even if it does not integrate the management of flags in the gamelist and the new systems included in recalbox 9 the theme remains compatible.
                        Même si il n'intègre pas la gestion des drapeaux dans les gamelist et les nouveaux systèmes inclus dans Recalbox 9 le thème reste compatible.
                        Recalboxment votre,
                        M__a__a__x
