    Autonomie GPi Case + Pi zero 2 W
    autonomie gpi case zero
    1904
    • cdtpepette
      cdtpepette last edited by
      Bonjour et grand merci à toute la communauté.👏 🎆
      J'utilise Recalbox 7.2.2 sur Gpi Case avec Pi zero et j'en suis très satisfait.
      Je me pose la question d'un upgrade Pi zero 2 en particulier pour ne plus avoir à utiliser pisnes mais Libretro Snes9x.
      Quand est-il de l'autonomie en comparaison du pi zero.
      Merci pour vos retours.
      Raspberry pi 4 2Go,RGBDual, Recalbox 8.1-64bits, share sur NAS nfs Yunohost (raspberry pi 3).
      Gpi Case Rpi 0 µSD 32Go Recalbox 8.1
      fabbris.ivano Scavy 2 Replies Last reply Reply Quote 0
      • fabbris.ivano
        fabbris.ivano @cdtpepette last edited by fabbris.ivano
        @cdtpepette near 2 hours, use top brand batteries
          Scavy Global moderator @cdtpepette last edited by Scavy
          @cdtpepette @fabbris-ivano
          Hi, take care, the GPiCase + the Pi02w card are not totally compatible. I often have a power problem with using batteries. No pb while using the gpi power cable.
          fabbris.ivano 1 Reply Last reply Reply Quote 0
          • cdtpepette
            Thanks for your reply. I'll wait and see.
            • fabbris.ivano
              fabbris.ivano @Scavy last edited by
              @scavy said in Autonomie GPi Case + Pi zero 2 W:
              what problem? mine is perfectly functioning
              maybe BETA software is the problem, no optimization.
              maybe in 3/4 week we can have a stable version.
              Ahchay 1 Reply Last reply Reply Quote 0
              • Ahchay
                Ahchay @fabbris.ivano last edited by
                @fabbris-ivano @Scavy
                I've just configured my GPi Case/Pi Zero 2 W and it won't boot on battery power - seems to get stuck
                in a loop between the initial "have fun with recalbox" screen and the "installing GPi Case" screen . So, has to be plugged in to USB to boot up and then can be removed from the power connector and will run on batteries quite happily.
                So, I guess, some part of the boot process draws just a tiny amount too much power and causes it to go into a bit of a meltdown.
                  Scavy Global moderator @Ahchay last edited by
                  @ahchay i have the save behaviour, and it's the same when Recalbox is installed and i ran it with battery. It loops.
                  • Ahchay
                    Ahchay @Scavy last edited by
                    @scavy slight update, I gave my (eneloop pro) batteries a full charge and it now managed to boot part the setup screen.
                    I don't get the installing gpi case screen any more, so not sure if the problem is permanently resolved or if it will start failing again when the batteries run down a bit, could be that now the safe shut down is executing it doesn't need to do that particular pay of the boot sequence any more
