    TUTO [EN] Deactivate GRUB menu selection
    Your recalbox
    [en] deactivate grub selection tuto
    • OOKAMIFR
      OOKAMIFR last edited by OOKAMIFR
      Hello
      First of all, I am french and prefered to write in english because this method is not difficult to understand 🙂
      I found a basic way to deactivate menu selection on startup (selection between normal or verbose)
      Recalbox - boot without any linux progress and launch video splash
      Recalbox (verbose) - show linux progress and launch video splash
      On my case, I use Recalbox on PC but this can be done from SD or USB stick
      From HDD or SSD
      If you already use Recalbox and avoid mount HDD - SSD on your PC
      connect to your machine via SSH
      mount -o remount,rw /boot
      cd /boot
      ls
      EFI hardware.log
      System Volume Information recalbox-backup.conf
      asound.state recalbox-boot.conf
      boot update
      boot.lst
      if you have configured your machine on UEFI
      cd EFI
      ls
      BOOT
      cd BOOT/
      ls
      bootia32.efi bootx64.efi grub.cfg
      if you don't have your machine configured on UEFI
      cd boot
      ls
      grub initrd.gz linux recalbox
      cd grub
      ls
      grub.cfg
      grub.cfg is the file about menu selection and time for selection
      to edit this file
      nano grub.cfg
      you will see this
      set default="0"
      set timeout="5"
      set menu_color_normal=cyan/blue
      set menu_color_highlight=white/blue
      menuentry "Recalbox" {
      set gfxpayload=auto
      linux /boot/linux label=RECALBOX console=tty3 quiet loglevel=0
      initrd /boot/initrd.gz
      menuentry "Recalbox (verbose)" {
      set gfxpayload=auto
      linux /boot/linux label=RECALBOX console=tty1 loglevel=7
      replace value set timeout="5" by "0"
      make CTRL+X to leave
      push Y to confirm save
      press ENTER to confirm the name and exit nano
      reboot your system to see the change
      have a good game 🙂
      100.7k
