    Boot from MicroSD, Backups on SSD (Nespi)
    Your recalbox
    boot backups ssd nespi
    • Metramo
      Metramo last edited by
      Hello.
      I have installed recalbox to an microsd 64 gb and it worked fine.
      I have the Nespi-Case, where i can connect 2.5 ssd. So i connected and it worked!
      Now i want a backup from a game to show up in the systems of emulationstation (psx).
      Where can i edit the paths? So that emulationstation is not longer pointing to the shared-folder, because i want it to load from ssd. How can i do that?
      And maybe i want to install recalbox on my ssd. How can i do that? Because i think i cant use the image for sd's?
      Best regards
      100.7k
