    Mando NES30 PRO de 8BITDO.
    Mandos/GPIO/Codificador USB
    mando nes30 8bitdo
    4676
    • sad1942
      sad1942 last edited by sad1942
      Ok.
      Prueba esto.
      Borra todo lo de tu fichero es_input.cfg y copia esto que te mando.
      <?xml version="1.0"?>
      <inputList>
      <!-- Keyboard -->
      <inputConfig type="keyboard" deviceName="Keyboard" deviceGUID="-1" deviceNbAxes="0" deviceNbHats="0" deviceNbButtons="120">
      <input name="a" type="key" id="115" value="1" code="168" />
      <input name="b" type="key" id="97" value="1" code="168" />
      <input name="down" type="key" id="1073741905" value="1" code="168" />
      <input name="hotkey" type="key" id="32" value="1" code="168" />
      <input name="left" type="key" id="1073741904" value="1" code="168" />
      <input name="pagedown" type="key" id="1073741902" value="1" code="168" />
      <input name="pageup" type="key" id="1073741899" value="1" code="168" />
      <input name="right" type="key" id="1073741903" value="1" code="168" />
      <input name="select" type="key" id="32" value="1" code="168" />
      <input name="start" type="key" id="13" value="1" code="168" />
      <input name="up" type="key" id="1073741906" value="1" code="168" />
      </inputConfig>
      <!-- Nes30 Pro 2 BT -->
      <inputConfig type="joystick" deviceName="8BitDo N30 Pro 2" deviceGUID="05000000c82d00006528000000010000" deviceNbAxes="6" deviceNbHats="1" deviceNbButtons="16">
      <input name="a" type="button" id="0" value="1" code="304" />
      <input name="b" type="button" id="1" value="1" code="305" />
      <input name="down" type="hat" id="0" value="4" code="16" />
      <input name="hotkey" type="button" id="10" value="1" code="314" />
      <input name="joystick1left" type="axis" id="0" value="-1" code="0" />
      <input name="joystick1up" type="axis" id="1" value="-1" code="1" />
      <input name="joystick2left" type="axis" id="2" value="-1" code="2" />
      <input name="joystick2up" type="axis" id="3" value="-1" code="5" />
      <input name="l2" type="button" id="8" value="1" code="312" />
      <input name="l3" type="button" id="13" value="1" code="317" />
      <input name="left" type="hat" id="0" value="8" code="16" />
      <input name="pagedown" type="button" id="7" value="1" code="311" />
      <input name="pageup" type="button" id="6" value="1" code="310" />
      <input name="r2" type="button" id="9" value="1" code="313" />
      <input name="r3" type="button" id="14" value="1" code="318" />
      <input name="right" type="hat" id="0" value="2" code="16" />
      <input name="select" type="button" id="10" value="1" code="314" />
      <input name="start" type="button" id="11" value="1" code="315" />
      <input name="up" type="hat" id="0" value="1" code="16" />
      <input name="x" type="button" id="3" value="1" code="307" />
      <input name="y" type="button" id="4" value="1" code="308" />
      </inputConfig>
      </inputList>
      • hytche54
        hytche54 last edited by
        Uoooo ahora va perfecto eres un maquina :)))) me faltaba esta linea verdad?
        Y solucionado el tema shaders como comentabas muchisimas gracias de verdad me traia loco xD
        Un saludo y muchas gracias por tu paciencia y ayudarme 🙂
        • sad1942
          No estoy seguro de que el problema fuera la linea <!-- Nes30 Pro 2 BT -->, creo que mas bien sería algún valor de los botones.
          En la última actualización de Recalbox hay algo que hace que el fichero es_input.cfg no se cree correctamente.
          De todos modos me alegro de que te funcione. Ha sido un placer haberte podido ayudar. 🙂
          Saludos
          • hytche54
            Un placer ati por ser tan amable 🙂
            • David Cabani
              David Cabani last edited by
              Me podeis hechar un cable a mi? Yo tengo la raspi 4 y el NES30 Pro (dos mandos) y se me apagan cuando inicio juego. Intento hacer esto que decis pero sigue pasando igual.
              100.1k
