    6.1.1 XU4 8Bitdo SN30 Pro+
    Testers's corner
    6.1.1 xu4 8bitdo sn30
    • olivierdroid92
      @Bkg2k @OyyoDams
      En complement de ce post
      https://forum.recalbox.com/topic/19444/6-1-1-rpi3b-plus-manettes-8bitdo-sn30-pro-et-sf30-pro/37
      Voici mon fichier \XU4\share\system.emulationstation\es_input.CFG avec SN30Pro+ et Firmware 3.02 (mis a jour et touches remappés)
      <inputConfig type="joystick" deviceName="8BitDo SN30 Pro+" deviceGUID="05000000c82d00000261000000010000" deviceNbAxes="4" deviceNbHats="1" deviceNbButtons="16">
      		<input name="a" type="button" id="0" value="1" code="304" />
      		<input name="b" type="button" id="1" value="1" code="305" />
      		<input name="down" type="hat" id="0" value="4" code="16" />
      		<input name="hotkey" type="button" id="2" value="1" code="306" />
      		<input name="joystick1left" type="axis" id="0" value="-1" code="0" />
      		<input name="joystick1up" type="axis" id="1" value="-1" code="1" />
      		<input name="joystick2left" type="axis" id="2" value="-1" code="2" />
      		<input name="joystick2up" type="axis" id="3" value="-1" code="5" />
      		<input name="l2" type="button" id="8" value="1" code="312" />
      		<input name="l3" type="button" id="13" value="1" code="317" />
      		<input name="left" type="hat" id="0" value="8" code="16" />
      		<input name="pagedown" type="button" id="7" value="1" code="311" />
      		<input name="pageup" type="button" id="6" value="1" code="310" />
      		<input name="r2" type="button" id="9" value="1" code="313" />
      		<input name="r3" type="button" id="14" value="1" code="318" />
      		<input name="right" type="hat" id="0" value="2" code="16" />
      		<input name="select" type="button" id="10" value="1" code="314" />
      		<input name="start" type="button" id="11" value="1" code="315" />
      		<input name="up" type="hat" id="0" value="1" code="16" />
      		<input name="x" type="button" id="3" value="1" code="307" />
      		<input name="y" type="button" id="4" value="1" code="308" />
      	</inputConfig>
      Je commence les tests.
      Pour info mon adapateur BT est un CSL - V4.0 USB nano Adaptateur Bluetooth avec DEL Class 4.0
