    Save Metadata on Exit
    Themes & Interface
    metadata
    • HapHzrd
      HapHzrd last edited by
      There used to be an option for "Save Metadata on Exit: [ON/OFF]"...
      Is this still available? I cannot find it. I want to disable this option like in the older versions.
      Thank you!
      • supernature2k
        supernature2k last edited by
        Hi,
        If you don't want to save metadata you can select "quick shutdown"
        • HapHzrd
          Thank you. I will try that.
