    Connexion SSH depuis Mac
    ssh mac
    • zeby1982
      zeby1982 last edited by
      Bonjour, je ne parviens pas à me connecter en SSH sur ma RecalBox, je reçois le message d'erreur suivant : <p class="p1"><span class="s1">Last login: Tue Jan 12 10:58:46 on console</span></p> <p class="p1"><span class="s1">AirdeSebastien:~ sebastienplace$ ssh root@192.168.2.83</span></p> <p class="p1"><span class="s1">@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@</span></p> <p class="p1"><span class="s1">@    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @</span></p> <p class="p1"><span class="s1">@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@</span></p> <p class="p1"><span class="s1">IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!</span></p> <p class="p1"><span class="s1">Someone could be eavesdropping on you right now (man-in-the-middle attack)!</span></p> <p class="p1"><span class="s1">It is also possible that a host key has just been changed.</span></p> <p class="p1"><span class="s1">The fingerprint for the ECDSA key sent by the remote host is</span></p> <p class="p1"><span class="s1">SHA256:rEpLDlu1hjd8zUAWps9iOBKjURBaYT3Z0xylpBkJDCc.</span></p> <p class="p1"><span class="s1">Please contact your system administrator.</span></p> <p class="p1"><span class="s1">Add correct host key in /Users/sebastienplace/.ssh/known_hosts to get rid of this message.</span></p> <p class="p1"><span class="s1">Offending ECDSA key in /Users/sebastienplace/.ssh/known_hosts:2</span></p> <p class="p1"><span class="s1">ECDSA host key for 192.168.2.83 has changed and you have requested strict checking.</span></p> <p class="p1"><span class="s1">Host key verification failed.</span></p>   <p class="p1"><span class="s1">AirdeSebastien:~ sebastienplace$ </span></p> <p class="p1"></p> <p class="p1">De plus je ne parviens pas à ajouter de jeu sur ma RecalBox car je ne la vois pas apparaître en réseau.</p> <p class="p1"></p> <p class="p1">Merci d'avance pour votre aide</p>
        Hello ssh-keygen -R ip dans un terminal avant retenter une connexion SSH résout-il le problème ? Pour ajouter des jeux, tu peux également passer par winscp. D'après le wiki, une version mac non officielle serait dispo. PS: merci de bien vouloir éditer ton message afin de le rendre lisible, merci.
          voljega Banned last edited by
          (C'est un bug du forum ces balises c'est bien chiant d'ailleurs)
            Je sais bien @vojega, mais ce n'est pas pour cela que l'on est dispensé d'utiliser la fonction édition pour virer les balises bugées 😉 Normalement le nouveau forum devrait arriver avec la release de la 3.3.0 en stable.
