    lr-mame2016
    Your recalbox
    lr-mame2016
    • Draugr
      Draugr last edited by
      Hi.
      I just downloaded and installed my Recalbox on my Rock64 SBC. There is a beta image available for the ystem and since it is more powerful than the Pi 3b+, I figured I'd try it out.
      Anyhow, I wanted to know if there is a way to get lr-mame2016 running on Recalbox? I've seen it listed on retropie thus I wanted to check it out on my Recalbox. i'm new to Recalbox so I'm not sure if lr-mame2016 can work and if so, how to set it up in Recalbox Manager (web interface).
      If lr-mame2016 is not compatible is 2014 or 2010?
      If anyone has any information, I'd appreciate it.
      Thanks,
      John
      PS: Oh, I have some ES themes I like that I was using on my RP3B retropie installation. I was wondering if I could use those for ES in Recalbox too?
      • olivierdroid92
        @Draugr
        Best result will be with MAME2003 core with associated romset MAME2003.
        On the beta version dated 2019-02-2x there is some issues with MAME2010
