    Solved Force emulationstation in 4/3 from a 16/9 screen
    Themes & Interface
    force 169
    • mYSt
      mYSt Theme moderator last edited by
      I need to make some 4/3 testing with my theme but i have no such screen and i can't figure out how to force 4/3. So far i tried to modify system.es.videomode=DMT 16 from conf and i tried to use tvservice command tvservice -m "DMT 16" but i got Invalid group. Anything else i can try?
      ps : i don't want to run cores in 4/3, i want emulationstation to run in 4/3
      Thx!
        voljega Banned @mYSt last edited by
        @myst recalbox.conf is for emulators, for ES you have to modify config.txt (if you use pi, otherwise I don't know)
        mYSt 1 Reply Last reply Reply Quote 0
        • mYSt
          mYSt Theme moderator @voljega last edited by
          @voljega Ok thx you lead me to the solution i modify config.txt with the following
          hdmi_drive=2
          hdmi_force_hotplug=1
          hdmi_group=2
          hdmi_mode=16
          and it works!
