    sin salida de audio desde ultimo update...
    Recalbox general
    sin salida audio desde ultimo
    • Fransis J. J
      Fransis J. J last edited by
      Buenas, desde que meti el ultimo update no me reconoce la salida de audio.
      he probado a definir "auto o jack" en el "recalbox.conf", o desde la interfaz web, pero no hace nada. no hay audio...
      he mirado los logs, y parece que el sistema en principio si que sigue reconociendo mis salidas de audio:
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.480934] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.610670] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC662 rev1: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.610673] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.610674] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.610675] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.610676] snd_hda_codec_realtek hdaudioC1D0: inputs:
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.610677] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.610678] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.610683] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.762694] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input11
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.765417] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input8
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.765531] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:14.2/sound/card1/input9
      Jul 11 21:46:28 RECALBOX user.info kernel: [ 10.765625] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:14.2/sound/card1/input10
      tambien he probado desde terminal "alsamixer", todos los volumenes estan al maximo, y me detecta correctamente mi controladora de audio por jack, realtek alc. osea parece un problema de los scrips, porque el sistema sigue reconociendo perfectamente el hardware, como lo puedo solucionar?
      Gracias
      Fransis J. J 1 Reply Last reply Reply Quote 0
      • Fransis J. J
        Fransis J. J @Fransis J. J last edited by
        @fransis-j-j
        en el log de emulationstation veo lo siguiente:
        lvl0: VolumeControl::init() - Failed to find mixer elements!
        lvl0: MUSIC Error - Unable to open SDLMixer audio: ALSA: Couldn't open audio device: No such file or directory
        lvl2: playing
        lvl2: Mix_PlayMusic: Audio device hasn't been opened
        • Quemandoacromo
          Quemandoacromo last edited by
          Si das más información es posible ayudarte mejor:
          • ¿Usas una Raspberry o PC?
          • ¿Usas tarjeta de sonido externa?
          • Fransis J. J
            hola,
            pues es un pc, y es la controladora integrada realteck alc662 creo....
            Gracias
            • Fransis J. J
              resuelto...
              resulta que era culpa del theme "clean retro", si pongo el theme normal si me funciona bien el volumen, no entiendo porque, pero es lo que me estaba pasando!
              salu2
              101.4k
