    installation script , lancement permission denied.
    installation script permission denied
    • Mikefly
      Mikefly last edited by Mikefly
      J'ai précommandé le boitier Snespi "the ursus snes pal" : https://www.kintaro.co/collections/shop/products/660b4bd9-bb17-4f52-aa56-fd679c0f704e
      et la team responsable du boitier ma donné le script a installer pour gerer le bouton on/off
      j'ai suivi la procédure :
      Hi There
      I've copied the setup from our dev doc. Please don't hesitate to let me know if it all makes sense as I understand it might be full of confusing terms.
      Preparation
      Connect to Wi-Fi by going to the Main Menu and click on Network Settings.
      Enable Wi-Fi and enter the SSiD (name of your Wi-Fi) and the password.
      Reboot your Raspberry Pi. Go to the network settings to look up your IP-Adress.
      Now that you know your IP-Adress you can connect to it via SSH. Either via the terminal (Linux
      and Mac) or Putty (Windows). Read the guides here:
      https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN)
      You'll need a SFTP connection. Read the guides here:
      https://github.com/recalbox/recalbox-os/wiki/Network-access-with-WinSCP-(EN)
      Installation
      In the SSH you enter the following command
      mount -o remount rw, /boot
      Download our files:
      https://github.com/MichaelKirsch/Kintaro-Recalbox
      Now go to your SFTP Program and copy the Kintaro folder into the /opt folder.
      Then you copy the S100kintaro.sh into /etc/init.d/ and activate it by entering the command
      /etc/init.d/S100kintaro.sh start
      voila à la derniere étape j'ai droit à ça : -sh: line 36: /etc/init.d/S100kintaro.sh: Permission denied
      comment faire pour avoir la permission d’exécuter la commande ?
      merci de votre aide ( je suis un noob )
      EDIT: apres avoir lancer cette commande : chmod +x /etc/init.d/S100kintaro.sh
      je n'ai pas eu droit au message d'erreur : mais a celui la :
      /etc/init.d$ /etc/init.d/S100kintaro.sh start
      Starting example.
      Donc je pense que c'est bon 😄
      Mikefly 1 Reply Last reply Reply Quote 0
      • Mikefly
        Mikefly @Mikefly last edited by Mikefly
        Bon voila j'ai reçu mon boitier Super Ursus de chez Kintaro. L'installation du script a bien fonctionné.
        donc en gros pour resumer l'installation du script il faut télécharger ces fichiers :
        j'ai utiliser ce logiciel WinSCP
        se connecter en mode root sur le pi3 et autoriser l’écriture sur la partition.
        copier le dossier Kintaro dans le repertoire /opt folder
        puis le fichier S100kintaro.sh dans le repertoire /etc/init.d/
        lancer la commande :
        chmod +x /etc/init.d/S100kintaro.sh (pour autoriser le fichier)
        et enfin lancer le script avec la commande suivante :
        normalement le message suivant apparait : Starting example.
        Super Ursus
        • Benny
          Benny last edited by Benny
          @Mikefly Je pense que je vais me laisser tenter par ce boîtier, merci pour ton retour 🙂
