    Problème son Medievil 2 PS1
    medievil ps1
    2820
    • Setsuki
      Setsuki last edited by
      Salut a tous, j'ai un problème sur mon raspberry pi 3b que j'ai eu récemment sur le jeu Medievil 2. En fait, lorsque je joue, le jeu fonctionne parfaitement bien mais parfois le jeu lit les pistes audio des niveau suivant lorsque je passe un écran de chargement ou que je parle au fantome. J'ai déja essayer de prendre d'autre iso mais même problème.
      Je me souvient que ce problème m'est déja arriver sur pc et malgré les changement de driver audio, rien ne change.
      Si quelqu'un a une solution, ce serait cool. Merci
      • mattitotti
        mattitotti last edited by
        @setsuki said in Problème son Medievil 2 PS1:
        hi setsuki have the same problem too... i'm Italian escuse me if i don't responde in francais for me it's a problem in the emulator...i hope that people responde to this topic
        Setsuki 1 Reply Last reply Reply Quote 0
        • Setsuki
          Setsuki @mattitotti last edited by
          @mattitotti Yes, i think it's a problem in the emulator too. I don't know what but i've try to change the sound plugin but it don't change anything.
          otherwise, I have no problem with English. There are no worries ^^
          • mattitotti
            i did the same think but nothing change... epsxe has the same glitch....but on epsxe 2.0 was fixed...is at 100% the emulator i'm sure
            • Setsuki
              That's right, I just tested and it works on epsxe 2.0.5. So, this is a glitch made by the emulator. Have you test this games on retropie? I would like test but I do not want to format and modify my SD card for something I'm not sure
              mattitotti 1 Reply Last reply Reply Quote 0
              • mattitotti
                mattitotti @Setsuki last edited by
                @setsuki
                i installed retropie but retropie run a 1.67 version of pcsx rearmend while recalbox run the version 1.69 as you can imagine....same result...otherwise worse infact retropie some times in the psx game has a drop of frame...for now notthing my friend
                • Setsuki
                  okay it's too bad. I will still play but only on my pc for the moment. If it works better in the nexts updates, I would do it again on the raspberry pi.
