    How to get out the developer and rating?
    Themes & Interface
    developer rating
    • vdallign
      vdallign last edited by
      Hello, i'm stating a new project with the recalbox.
      My question is:
      How do I get off the rating and developer information when I select a console?
      Its that information that appears in the list of games, I can change this informations by working on the .xml file, but I liked to get off this infos, that's possible?
      Thank you by all and happy Christmas
      • NantoFirebird
        NantoFirebird last edited by
        Hi @vdallign.
        I don't know if you're still looking for a solution, if that's the case I have some answers for you.
        I am not sure that you can simply disable the display of these elements, nevertheless I know two workarounds. These tricks involve modifying the xml files of the theme.
        The first solution is to use a special font that does not display any characters. The second, simpler, is to move the items you don't want to see by giving x/y positions greater than 1, in order to display them outside the screen.
        I hope this will be usefull to you 🙂
