Problem with Recalbox 9.2 Experimental-2 on RPI5
Hi, I'm new to the Forum so I'd like to take this opportunity to say hello to everyone. I don't know if I'm in the right category but I have a problem with Recalbox 9.2 Experimantal-2 on RPI5. After upgrading from Experimental-1 to Experimental-2, RPI5 often freezes, slows down, does not load and is very slow. When it gets stuck, the green LED light is off for 5-15 seconds, then it turns on again and recalbox goes on charging and doing its job. Is this a problem with the new beta update that needs to be resolved or do I need to change some settings to make it work properly? Because it is not usable like this, the roms crash very often. Because RPI5 crashes continuously. With Experimental-1 however everything was perfect. Thanks for those who help me.
@Pyper I have similar problems. When I choose game console menu list or game list, my rbp5 does a lot of short freezing.
And after freezing, the menu cursor moves 2 or 3 step of the list. -
@Pyper Hello, I think I have found the solution to this problem, I hope it helps you; The system runs slow because it takes a high resolution from your TV or monitor. When starting my reclabox it always defaulted to 4K, so the system was slow when entering the console menu. I found in the raspberry forum the following code that you must write at the end of the line in the cmdline.txt file of the "recalbox" partition on your SD:
video=HDMI-A-1:1920x1080iThis line will force Recalbox to enter the resolution you want when starting the system; you can even lower the resolution if you need it.
