<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[psx ebbot savestate problem]]></title><description><![CDATA[<p dir="auto">hello guys,<br />
i've converted all psx games to an eboot-file and now, when i'm loading a different eboot game (eg spiderman), recalbox loads a savestate from thony hawk pro skater 4...<br />
How can i solve this problem? And whats the reason for this?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.recalbox.com/topic/8398/psx-ebbot-savestate-problem</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Mar 2026 21:23:12 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/8398.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Jul 2017 19:55:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to psx ebbot savestate problem on Mon, 31 Jul 2017 12:35:31 GMT]]></title><description><![CDATA[<p dir="auto">ok i solved it:<br />
i've pressed the HOME + X Button while psx emulation to get into the retroarch menu and set autoload save stage and autosave stage to OFF in the loading config. Then i've manually updated my config file in configurations menu, activated "save config on exit"-option and selected "quit retroarch". NOT it works fine and i dont have to rename ALL the psx eboot files xD<br />
thanks to myself for this solution haha</p>
]]></description><link>https://forum.recalbox.com/post/62968</link><guid isPermaLink="true">https://forum.recalbox.com/post/62968</guid><dc:creator><![CDATA[Chris Matthes]]></dc:creator><pubDate>Mon, 31 Jul 2017 12:35:31 GMT</pubDate></item><item><title><![CDATA[Reply to psx ebbot savestate problem on Thu, 27 Jul 2017 12:09:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/37">@rockaddicted</a> said in <a href="/post/62569">psx ebbot savestate problem</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/15080">@chris-matthes</a> game and associated savestate files must have the same name. Only extensions are differents.<br />
So check your files names.</p>
</blockquote>
<p dir="auto">I had thought so... I only have to rename all my psx games.<br />
But my other question was, why is there a save state? I've never activated this function and i dont know where it shoul be... <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--disappointed" title=":(" alt="😞" /><br />
Can i access the .sav files to delete it?<br />
And can i rename my files via the Monitorin and Tranfer-UI in the Webbrowser, or I have to delete them from Recalbox, rename it on my file system and transfer it again?</p>
]]></description><link>https://forum.recalbox.com/post/62591</link><guid isPermaLink="true">https://forum.recalbox.com/post/62591</guid><dc:creator><![CDATA[Chris Matthes]]></dc:creator><pubDate>Thu, 27 Jul 2017 12:09:56 GMT</pubDate></item><item><title><![CDATA[Reply to psx ebbot savestate problem on Thu, 27 Jul 2017 07:04:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/15080">@chris-matthes</a> game and associated savestate files must have the same name. Only extensions are differents.<br />
]]></description><link>https://forum.recalbox.com/post/62569</link><guid isPermaLink="true">https://forum.recalbox.com/post/62569</guid><dc:creator><![CDATA[rockaddicted]]></dc:creator><pubDate>Thu, 27 Jul 2017 07:04:48 GMT</pubDate></item></channel></rss>
