<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problems SHUT DOWN&#x2F;RESTART&#x2F; FAST SHUT DOWN or UPDATING GAMES DATA]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I was using my recalbox 4.0.2  in raspberry pi 3 without any problems for a month. Today when I started it the system was not starting as normal, showing the multicolour square pattern screen at the begining and then showing a text message (is soo fast and i cant take a screenshot of it) then goes to the recalbox logo and restarts again a few times until finally it starts correctly. If I choose any of the options: SHUT DOWN/RESTART/ FAST SHUT DOWN or UPDATING GAMES DATE the system doesnt shut down and always restarts doing the same thing I have explained before. If I put new games and i add the info and scrap them, once i shut/restart the information is not saved....</p>
<p dir="auto">Could you give me some advice. Thanks in advance!</p>
]]></description><link>https://forum.recalbox.com/topic/8226/problems-shut-down-restart-fast-shut-down-or-updating-games-data</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Mar 2026 01:48:28 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/8226.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Jul 2017 12:48:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problems SHUT DOWN&#x2F;RESTART&#x2F; FAST SHUT DOWN or UPDATING GAMES DATA on Wed, 12 Jul 2017 17:24:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/14249">@danimourinho</a> bad quality psu don't deliver what they promise. Sometimes the adapter itself is good, but the micro USB isn't.</p>
]]></description><link>https://forum.recalbox.com/post/61414</link><guid isPermaLink="true">https://forum.recalbox.com/post/61414</guid><dc:creator><![CDATA[paradadf]]></dc:creator><pubDate>Wed, 12 Jul 2017 17:24:36 GMT</pubDate></item><item><title><![CDATA[Reply to Problems SHUT DOWN&#x2F;RESTART&#x2F; FAST SHUT DOWN or UPDATING GAMES DATA on Wed, 12 Jul 2017 16:12:29 GMT]]></title><description><![CDATA[<p dir="auto">I have a 5V - 3.0A usb adaptor and thats the one I was using and giving me problems. I have swaped to a similar one and seems that is not doing that, so definetely is a power issue. In the right top corner is showing a yellow Lighning icon all the time. I have read that this is because the RPI3 is underpowered. I thought 5v and 3A would be enough....</p>
]]></description><link>https://forum.recalbox.com/post/61405</link><guid isPermaLink="true">https://forum.recalbox.com/post/61405</guid><dc:creator><![CDATA[danimourinho]]></dc:creator><pubDate>Wed, 12 Jul 2017 16:12:29 GMT</pubDate></item><item><title><![CDATA[Reply to Problems SHUT DOWN&#x2F;RESTART&#x2F; FAST SHUT DOWN or UPDATING GAMES DATA on Wed, 12 Jul 2017 15:59:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/2215">@lackyluuk</a> you are completely right.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/14249">@danimourinho</a> sorry about that!</p>
<p dir="auto">Maybe your sd card got corrupted!</p>
]]></description><link>https://forum.recalbox.com/post/61403</link><guid isPermaLink="true">https://forum.recalbox.com/post/61403</guid><dc:creator><![CDATA[paradadf]]></dc:creator><pubDate>Wed, 12 Jul 2017 15:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to Problems SHUT DOWN&#x2F;RESTART&#x2F; FAST SHUT DOWN or UPDATING GAMES DATA on Wed, 12 Jul 2017 14:00:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/14249">@danimourinho</a> <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/1314">@paradadf</a><br />
I think he means the square screen during startup <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":)" alt="🙂" /> This is a normal function of the RPi. Has nothing to do with your power supply.<br />
ONLY if you see a small rainbow square in the upper right corner WHILE running, then you have a power supply issue.</p>
<p dir="auto">Did you change some files, data, custom configs?</p>
]]></description><link>https://forum.recalbox.com/post/61388</link><guid isPermaLink="true">https://forum.recalbox.com/post/61388</guid><dc:creator><![CDATA[lackyluuk]]></dc:creator><pubDate>Wed, 12 Jul 2017 14:00:51 GMT</pubDate></item><item><title><![CDATA[Reply to Problems SHUT DOWN&#x2F;RESTART&#x2F; FAST SHUT DOWN or UPDATING GAMES DATA on Wed, 12 Jul 2017 13:25:30 GMT]]></title><description><![CDATA[<p dir="auto">thanks I will try with another charger then, and let you know</p>
]]></description><link>https://forum.recalbox.com/post/61379</link><guid isPermaLink="true">https://forum.recalbox.com/post/61379</guid><dc:creator><![CDATA[danimourinho]]></dc:creator><pubDate>Wed, 12 Jul 2017 13:25:30 GMT</pubDate></item><item><title><![CDATA[Reply to Problems SHUT DOWN&#x2F;RESTART&#x2F; FAST SHUT DOWN or UPDATING GAMES DATA on Wed, 12 Jul 2017 13:01:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/14249">@danimourinho</a> that rainbow square means your power supply isn't working good.</p>
]]></description><link>https://forum.recalbox.com/post/61375</link><guid isPermaLink="true">https://forum.recalbox.com/post/61375</guid><dc:creator><![CDATA[paradadf]]></dc:creator><pubDate>Wed, 12 Jul 2017 13:01:22 GMT</pubDate></item></channel></rss>
