<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[problem with smb.config permission]]></title><description><![CDATA[<p dir="auto">hi everyone, I installed  recalbox on raspberry pi 3 it's ok ,  but when i try to configuring kodi and add resource  set a share folder with windows, the solution is  change a line in  /etc/samba/smb.conf<br />
"wins support = no"  change for  "wins support = yes" and uncomment</p>
<p dir="auto">but when I connect with ssh and  ran   nano /etc/samba/smb.conf and try change the line I get error  "file is read only"    if i try  with sudo  "sudo: no command found"</p>
<p dir="auto">someone would can help me?</p>
<p dir="auto">regards.</p>
]]></description><link>https://forum.recalbox.com/topic/7498/problem-with-smb-config-permission</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 17:37:05 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/7498.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Apr 2017 17:42:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to problem with smb.config permission on Wed, 26 Apr 2017 10:06:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/12337">@mreddy86</a> said in <a href="/post/56042">problem with smb.config permission</a>:</p>
<blockquote>
<p dir="auto">if i try  with sudo  "sudo: no command found"</p>
</blockquote>
<p dir="auto">dude, you're root, why sudo ? lol<br />
And yes, you need to follow the wiki <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/11202">@pepe</a> pointed you to</p>
]]></description><link>https://forum.recalbox.com/post/56117</link><guid isPermaLink="true">https://forum.recalbox.com/post/56117</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Wed, 26 Apr 2017 10:06:30 GMT</pubDate></item><item><title><![CDATA[Reply to problem with smb.config permission on Tue, 25 Apr 2017 17:50:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/12337">@mreddy86</a> please, check this: <a href="https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)" rel="nofollow ugc">https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)</a>.</p>
]]></description><link>https://forum.recalbox.com/post/56044</link><guid isPermaLink="true">https://forum.recalbox.com/post/56044</guid><dc:creator><![CDATA[Pepe]]></dc:creator><pubDate>Tue, 25 Apr 2017 17:50:15 GMT</pubDate></item></channel></rss>
