<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problems with cheats]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I just worked myself into RPi3 and recalbox for a couple of days now and ran into a problem I can't seem to solve.</p>
<p dir="auto">I previously used ePSXe for Playstation emulation on my PC and I have a downloaded cheat txt with a bunch of well working cheats.<br />
Now that I switched to recalbox I converted these cheat codes into a .cht file which I successfully loaded in RetroArch.<br />
The problem is that some of the cheats just won't work and I can't figure out, why some of them work and some don't.<br />
Is there anything I might have missed?</p>
<p dir="auto">Thanks in advance! <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":)" alt="🙂" /></p>
<p dir="auto"><strong>ePSXe Cheat file excerpt:</strong><br />
#Infinite Shotgun Ammo	<br />
8008C5B4 0012<br />
#Infinite Uzis Ammo	<br />
8008C5B0 00A0<br />
#Have All Weapons	<br />
80088AA0 000B</p>
<p dir="auto"><strong>My cht file:</strong><br />
cheats = 2</p>
<p dir="auto">cheat0_desc = "Ammo test" <strong>&lt;- Doesn't work</strong><br />
cheat0_code = "8008C5B4+0012+8008C5B0+00A0"<br />
cheat0_enable = "false"</p>
<p dir="auto">cheat1_desc = "Weapons test" <strong>&lt;- Works</strong><br />
cheat1_code = "80088AA0+000B"<br />
cheat1_enable = "false"</p>
<p dir="auto"><strong>System/Game Specs:</strong><br />
Recalbox 4.0.0-final on RPi3 Model B<br />
Tomb Raider 2 (U).PBP</p>
]]></description><link>https://forum.recalbox.com/topic/5527/problems-with-cheats</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 17:41:41 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/5527.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Dec 2016 12:59:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problems with cheats on Tue, 03 Jan 2017 04:35:54 GMT]]></title><description><![CDATA[<p dir="auto">said in <a href="/post/null">Problems with cheats</a>:</p>
<blockquote>
<p dir="auto">on</p>
</blockquote>
<p dir="auto">May i ask, where you download the cheat file?<br />
I want to use cheat on PSX Grandia. But the cheat doesnt include.</p>
]]></description><link>https://forum.recalbox.com/post/40974</link><guid isPermaLink="true">https://forum.recalbox.com/post/40974</guid><dc:creator><![CDATA[raja-beras-terry]]></dc:creator><pubDate>Tue, 03 Jan 2017 04:35:54 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with cheats on Fri, 30 Dec 2016 17:30:35 GMT]]></title><description><![CDATA[<p dir="auto">Could it be that PCSX_reARMed only reads single-code cheats? As soon as I add more, it just won't work. <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--confused" title=":/" alt="😕" /></p>
<p dir="auto">EDIT: Tried some other games with the included cheats from RetroArch. Can confirm that cheats with more than one code won't work in PSX.</p>
]]></description><link>https://forum.recalbox.com/post/40551</link><guid isPermaLink="true">https://forum.recalbox.com/post/40551</guid><dc:creator><![CDATA[uniQ168]]></dc:creator><pubDate>Fri, 30 Dec 2016 17:30:35 GMT</pubDate></item></channel></rss>
