<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with the Rom USB]]></title><description><![CDATA[<ol>
<li>To use the ROM via the USB recalbox you must be disconnected from the Internet?</li>
<li>The Rom who have entered via network / recalbox / roms / ... are also saved on the SD recalbox? Or are only saved on the desktop PC?</li>
</ol>
]]></description><link>https://forum.recalbox.com/topic/4521/problem-with-the-rom-usb</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 08:40:07 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/4521.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 30 Oct 2016 18:31:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with the Rom USB on Sun, 30 Oct 2016 22:54:56 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/4626">@Manuel-Giuseppe-Trizzo</a>! I don't speak italian, but easy answers I can just translate <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--wink" title=";)" alt="😉" /></p>
<ol>
<li>The USB storage has nothing to do with internet... You don't need internet for that.</li>
<li>I'm not sure I understand you. You can save your roms either on your SD Card, or use an USB Stick to store your roms there. You can't use (yet) both. If you transfer a rom through the network, you copy it to your selected storage. If you use an USB Stick, you can just plug it on your PC and copy the roms directly.</li>
</ol>
]]></description><link>https://forum.recalbox.com/post/33073</link><guid isPermaLink="true">https://forum.recalbox.com/post/33073</guid><dc:creator><![CDATA[paradadf]]></dc:creator><pubDate>Sun, 30 Oct 2016 22:54:56 GMT</pubDate></item></channel></rss>
