<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem connecting second CSL wireless gamepad]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">Love my Recalbox Dual Setup so far, great software!</p>
<p dir="auto">I managed to connect my first controller, but I fail to connect the second one as well.</p>
<p dir="auto">My setup:</p>
<ul>
<li>Raspberry Pi 1</li>
<li>Dualboot System with LibreElec</li>
<li>Two CSL - Wireless Gamepad</li>
</ul>
<p dir="auto"><a href="https://www.amazon.de/dp/B01AQTSXTE/ref=cm_sw_r_cp_api_q5obyb9T5JFYR" rel="nofollow ugc">https://www.amazon.de/dp/B01AQTSXTE/ref=cm_sw_r_cp_api_q5obyb9T5JFYR</a></p>
<ul>
<li>One CSL - USB nano Bluetooth-Adapter V4.0</li>
</ul>
<p dir="auto"><a href="https://www.amazon.de/dp/B00C68IQ3C/ref=cm_sw_r_cp_api_J6obyb59V9N70" rel="nofollow ugc">https://www.amazon.de/dp/B00C68IQ3C/ref=cm_sw_r_cp_api_J6obyb59V9N70</a></p>
<p dir="auto">Both gamepads came with an usb dongle already. When I plug on of those usb dongles I can connect one gamepad without a problem. But when I scan for more devices it will not show the second gamepad.</p>
<p dir="auto">The problem is: I was not able to connect even only gamepad with the csl usb adapter that I bought separately and I'm also not able to connect both dongles that came with the gamepads.</p>
<p dir="auto">Any help on how to get both gamepads up and running is greatly appreciated. Let me know if I can provide additional information. Thanks in advance!</p>
]]></description><link>https://forum.recalbox.com/topic/4402/problem-connecting-second-csl-wireless-gamepad</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 01:15:27 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/4402.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Oct 2016 15:36:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem connecting second CSL wireless gamepad on Mon, 17 Oct 2016 16:21:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/4716">@Manuel-Raimund</a> of course... look for a usb hub (powered are better).</p>
]]></description><link>https://forum.recalbox.com/post/32110</link><guid isPermaLink="true">https://forum.recalbox.com/post/32110</guid><dc:creator><![CDATA[paradadf]]></dc:creator><pubDate>Mon, 17 Oct 2016 16:21:59 GMT</pubDate></item><item><title><![CDATA[Reply to Problem connecting second CSL wireless gamepad on Mon, 17 Oct 2016 16:16:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/1314">@paradadf</a> thank you for the quick reply! I was not aware of that, thanks. Is there by any chance some kind of splitter in which I can connect both dongles but use up only one usb port on my raspberry?</p>
]]></description><link>https://forum.recalbox.com/post/32109</link><guid isPermaLink="true">https://forum.recalbox.com/post/32109</guid><dc:creator><![CDATA[Manuel Raimund]]></dc:creator><pubDate>Mon, 17 Oct 2016 16:16:29 GMT</pubDate></item><item><title><![CDATA[Reply to Problem connecting second CSL wireless gamepad on Mon, 17 Oct 2016 15:52:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/4716">@Manuel-Raimund</a> those pads aren't bluetooth controllers. You MUST use both dongles they came with in order to play.</p>
]]></description><link>https://forum.recalbox.com/post/32106</link><guid isPermaLink="true">https://forum.recalbox.com/post/32106</guid><dc:creator><![CDATA[paradadf]]></dc:creator><pubDate>Mon, 17 Oct 2016 15:52:28 GMT</pubDate></item></channel></rss>
