<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[RESOLVED]Composite video on R pi model b]]></title><description><![CDATA[<p dir="auto">I'm not able to get composite video to work on Recalbox using the composite video port on the rpi model b (original). I have tried editing the config.txt file to comment hdmi lines and to enable sdtv_mode=2 and to add hdmi_ignore_hotplug = 1 but I dont get a picture and the pi wont boot so I have to format the card to get it working again. I have tried a standard composite lead in the yellow socket on r pi and I have tried a 3.5mm jack to rca cable also. What am I doing wrong?</p>
]]></description><link>https://forum.recalbox.com/topic/344/resolved-composite-video-on-r-pi-model-b</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 20:18:00 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/344.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 Mar 2015 17:40:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [RESOLVED]Composite video on R pi model b on Thu, 19 Mar 2015 21:52:01 GMT]]></title><description><![CDATA[<p dir="auto">Thanks I checked your settings and commented out the noobs section hdmi settings and its now working.</p>
]]></description><link>https://forum.recalbox.com/post/5315</link><guid isPermaLink="true">https://forum.recalbox.com/post/5315</guid><dc:creator><![CDATA[pdaboy]]></dc:creator><pubDate>Thu, 19 Mar 2015 21:52:01 GMT</pubDate></item><item><title><![CDATA[Reply to [RESOLVED]Composite video on R pi model b on Thu, 19 Mar 2015 18:14:12 GMT]]></title><description><![CDATA[<p dir="auto">I asume that you have to use the yellow socket. I have a raspberry pi 2. My file /boot/config.txt looks lite this to use the composite output:</p>
<pre><code># uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
disable_overscan=0
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# comment to get jack audio
#hdmi_drive=2
#config_hdmi_boost=0
#hdmi_force_hotplug=0
# uncomment to ignore hdmi plug
hdmi_ignore_hotplug=1
# uncomment for composite PAL
sdtv_mode=2
# Overclock
gpu_mem=512
avoid_safe_mode=1
kernel=zImage
# NOOBS Auto-generated Settings:
#hdmi_force_hotplug=1
#config_hdmi_boost=4
#overscan_left=24
#overscan_right=24
#overscan_top=16
#overscan_bottom=16
disable_overscan=0
overscan_scale=1
</code></pre>
<p dir="auto">You have to comment some lines (with hdmi mention). Do you notice some differences with yours?</p>
]]></description><link>https://forum.recalbox.com/post/5305</link><guid isPermaLink="true">https://forum.recalbox.com/post/5305</guid><dc:creator><![CDATA[imaster]]></dc:creator><pubDate>Thu, 19 Mar 2015 18:14:12 GMT</pubDate></item></channel></rss>
