<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Model 3 not working cause of 2 Arcade Sticks !!!]]></title><description><![CDATA[<p dir="auto">Topic: SEGA MODEL 3 on PC setup...and the cause (I'm really going crazy !!!):</p>
<p dir="auto">First I tried to get the Sega Model 3 roms to run on a Mini PC with an i5 4590T. This all failed even after weeks (real romset meanwhile at the start) !!!<br />
My thought then was: Only with a new, better mini pc they will run. So i bought a mini pc with an i5 6500T.<br />
AND: They run...until I finally found the problem now.</p>
<p dir="auto">I think: IT'S THE DRAGONRISE USB CONTROLLER from an EG-Starts Set !</p>
<p dir="auto">If I have both connected (P1 and P2), the games do not start (error message cause of missingf BIOS etc.).<br />
If only one is connected (P1) and the other (P2) is disconnected from the USB port of the computer, the games start perfectly...even on the computer that I had previously in the system.</p>
<p dir="auto">Then I tried using to control the games with an X-Box One controller and that works fine too.</p>
<p dir="auto">Then I tested a TWIN-USB (SJ@JX 2 Player LED Arcade USB Encoder) encoder (both sticks and buttons connected on a single board). Same thing here too: If only one stick and buttons are connected on the board, then the roms run, if both sticks are connected, the games do not start).</p>
<p dir="auto">What the hell is the reason for that <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--wink" title=";-)" alt="😉" /></p>
<p dir="auto">For a solution I would be superthankful...on gladly with instruction, if I must change a config or something similar.</p>
]]></description><link>https://forum.recalbox.com/topic/30125/model-3-not-working-cause-of-2-arcade-sticks</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 14:22:46 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/30125.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Apr 2023 21:00:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Model 3 not working cause of 2 Arcade Sticks !!! on Mon, 17 Apr 2023 22:41:34 GMT]]></title><description><![CDATA[<p dir="auto">OK...now I have it:<br />
Only if the X-Box controller is set to P1 in the system, the games start....regal which USB encoders are then for P2 and P3 at the start...STRANGE !!! X-Input and D-Input issue ?</p>
]]></description><link>https://forum.recalbox.com/post/185976</link><guid isPermaLink="true">https://forum.recalbox.com/post/185976</guid><dc:creator><![CDATA[Sesto2k]]></dc:creator><pubDate>Mon, 17 Apr 2023 22:41:34 GMT</pubDate></item><item><title><![CDATA[Reply to Model 3 not working cause of 2 Arcade Sticks !!! on Mon, 17 Apr 2023 21:21:37 GMT]]></title><description><![CDATA[<p dir="auto">I would like to mention in addition:</p>
<p dir="auto">If I use the Single USB Encoder from EG-Starts at P2...and in addition the Twin USB Encoder from SJ@JX at P1, then the Roms run...<br />
Is this related to the addressing and that Sega Model 3 may not be able to handle two of the same USB encoders ?</p>
]]></description><link>https://forum.recalbox.com/post/185975</link><guid isPermaLink="true">https://forum.recalbox.com/post/185975</guid><dc:creator><![CDATA[Sesto2k]]></dc:creator><pubDate>Mon, 17 Apr 2023 21:21:37 GMT</pubDate></item></channel></rss>
