<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Recalbox as an application]]></title><description><![CDATA[<p dir="auto">I've been willing to run Recalbox on Ubuntu desktop for a while.</p>
<ul>
<li>It run successfully inside VirtualBox, inside Gnome Boxes it did not work (but I didn't troubleshoot it well) but it ran bit too choppy for me to enjoy.</li>
<li>Compiling it didn't work well either; I needed to download so many runtimes and things that it completely defeated the purpose of it.</li>
</ul>
<p dir="auto">And I'd like to know;<br />
Is there an AppImage, Docker container, Flatpak or Snap of Recalbox which I can run inside a Linux Distrubution?<br />
Or, How can I make an appimage of the Recalbox so I can run it on Linux desktop?<br />
(edit)<br />
Or, Can I extract the files from the image and run it with <code>chroot</code> or other suggestion so I can just "install" it in Ubuntu ?</p>
]]></description><link>https://forum.recalbox.com/topic/29483/recalbox-as-an-application</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 07:10:28 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/29483.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 03 Dec 2022 16:38:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Recalbox as an application on Tue, 13 Dec 2022 06:24:42 GMT]]></title><description><![CDATA[<p dir="auto">Since recalbox is an operating system, it will not run as a standalone app like RetroPie. Instead, you must connect the device to a monitor and use (usually an original) controller connected to the actual device to play games. This can be thought of in many ways as turning a modern gaming console into a retro video game console.</p>
]]></description><link>https://forum.recalbox.com/post/184483</link><guid isPermaLink="true">https://forum.recalbox.com/post/184483</guid><dc:creator><![CDATA[luztolen1126]]></dc:creator><pubDate>Tue, 13 Dec 2022 06:24:42 GMT</pubDate></item><item><title><![CDATA[Reply to Recalbox as an application on Thu, 08 Dec 2022 21:41:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/10627">@Nazgulh</a></p>
<p dir="auto">I'm looking for help to compile this:<br />
<a href="https://gitlab.com/recalbox/recalbox-emulationstation" rel="nofollow ugc">https://gitlab.com/recalbox/recalbox-emulationstation</a></p>
<p dir="auto">However, there are some dependencies missing:</p>
<pre><code>CMake Warning (dev) at /usr/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:438 (message):
  The package name passed to `find_package_handle_standard_args` (SDLMIXER)
  does not match the name of the calling package (SDL2MIXER).  This can lead
  to problems in calling code that expects `find_package` result variables
  (e.g., `_FOUND`) to follow a certain pattern.
Call Stack (most recent call first):
  CMake/Packages/FindSDL2MIXER.cmake:49 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
  CMakeLists.txt:57 (find_package)
This warning is for project developers.  Use -Wno-dev to suppress it.
</code></pre>
  The package name passed to `find_package_handle_standard_args` (PkgConfig)
  does not match the name of the calling package (PulseAudio).  This can lead
  /usr/share/cmake-3.22/Modules/FindPkgConfig.cmake:99 (find_package_handle_standard_args)
  CMake/Packages/FindPulseAudio.cmake:30 (include)
  CMakeLists.txt:60 (find_package)
</code></pre>
<p dir="auto">Do you have experience in compiling things on Linux?<br />
I like Recalbox a lot more than the other EmulationStation that runs on Raspberry Pi/PC and others (that one I can compile following the instructions but Recalbox didn't work because of some missing dependencies.)</p>
]]></description><link>https://forum.recalbox.com/post/184423</link><guid isPermaLink="true">https://forum.recalbox.com/post/184423</guid><dc:creator><![CDATA[LuigiPuzo]]></dc:creator><pubDate>Thu, 08 Dec 2022 21:41:27 GMT</pubDate></item><item><title><![CDATA[Reply to Recalbox as an application on Sat, 03 Dec 2022 20:32:36 GMT]]></title><description><![CDATA[<p dir="auto">recalbox is not a application is a operating system.<br />
so it's impossible tu run recalbox  on any Os.</p>
]]></description><link>https://forum.recalbox.com/post/184384</link><guid isPermaLink="true">https://forum.recalbox.com/post/184384</guid><dc:creator><![CDATA[Nazgulh]]></dc:creator><pubDate>Sat, 03 Dec 2022 20:32:36 GMT</pubDate></item></channel></rss>
