<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trouble using GASIA controller REcalbox 4.0 and RASPBERRY PI3]]></title><description><![CDATA[<p dir="auto">Hi everyone,   I tried many time to set up my GASIA controllare PS3 clone. I was able to play trough usb cable but only if I reboot the system everytime I connect it. It was impossible for me to work in wireless mode....   Culd anyone help me?   Thank you in advance</p>
]]></description><link>https://forum.recalbox.com/topic/2880/trouble-using-gasia-controller-recalbox-4-0-and-raspberry-pi3</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 12:08:29 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/2880.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 May 2016 18:36:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trouble using GASIA controller REcalbox 4.0 and RASPBERRY PI3 on Wed, 05 Jul 2017 01:42:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi i have the same problema, idk that mi control is a fake , but you solved the problem? Help me plz my usb is a V2.0 is ok? My usb detect the control of ps3 but the Bluetooth not yet.<br />
Sorry for my english</p>
]]></description><link>https://forum.recalbox.com/post/60848</link><guid isPermaLink="true">https://forum.recalbox.com/post/60848</guid><dc:creator><![CDATA[alexisioo]]></dc:creator><pubDate>Wed, 05 Jul 2017 01:42:09 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble using GASIA controller REcalbox 4.0 and RASPBERRY PI3 on Thu, 02 Jun 2016 13:57:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/866">@esmith13</a> try <code>hcitool --scan</code> to scan for BT devices. When a sixaxis is plugged, a UDEV rule manages the launch of sixpair</p>
]]></description><link>https://forum.recalbox.com/post/21860</link><guid isPermaLink="true">https://forum.recalbox.com/post/21860</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Thu, 02 Jun 2016 13:57:04 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble using GASIA controller REcalbox 4.0 and RASPBERRY PI3 on Thu, 02 Jun 2016 11:26:40 GMT]]></title><description><![CDATA[<p dir="auto">any ideas then why tested controller, cable and usb BT dongle that work on a Pi2 might fail on a Pi3? any linux commands I can run to visually monitor the attempt to pair or connect?   thanks in advance for any help.</p>
]]></description><link>https://forum.recalbox.com/post/21855</link><guid isPermaLink="true">https://forum.recalbox.com/post/21855</guid><dc:creator><![CDATA[esmith13]]></dc:creator><pubDate>Thu, 02 Jun 2016 11:26:40 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble using GASIA controller REcalbox 4.0 and RASPBERRY PI3 on Thu, 02 Jun 2016 11:25:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/866">@esmith13</a> the Pi3 internal BT is not even started in linux, so you can't have any conflict.</p>
]]></description><link>https://forum.recalbox.com/post/21854</link><guid isPermaLink="true">https://forum.recalbox.com/post/21854</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Thu, 02 Jun 2016 11:25:03 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble using GASIA controller REcalbox 4.0 and RASPBERRY PI3 on Thu, 02 Jun 2016 11:02:37 GMT]]></title><description><![CDATA[<p dir="auto">b*mp?</p>
]]></description><link>https://forum.recalbox.com/post/21850</link><guid isPermaLink="true">https://forum.recalbox.com/post/21850</guid><dc:creator><![CDATA[esmith13]]></dc:creator><pubDate>Thu, 02 Jun 2016 11:02:37 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble using GASIA controller REcalbox 4.0 and RASPBERRY PI3 on Wed, 01 Jun 2016 16:52:04 GMT]]></title><description><![CDATA[<p dir="auto">I am having the same issue. Pi3, Gasia PS3 controllers. Set config to use gasia controllers. Using USB Dongle since I know built in bluetooth does not work yet. Plugged controllers in to Pi3 with USB cable for 30 seconds. Disconnect cable and turn on controller. No connectivity. Controller, cable and USB dongle all work fine on my Pi2. I have done this config many times without issue. Issue exists on two different Pi3's set up the same way. Is it possible that while built in bluetooth doesn't work, the USB bluetooth is being ignored as a SECOND bluetooth device? Is there a way to verify which bluetooth is the active one or to see the pairing status at the command prompt? Again, I have done this many times already and Pi2's always work and Pi3's always fail... Tried both the 4.x beta3 and 4.x unstable builds. (only versions supporting both Pi2 &amp; Pi3) Any ideas or troubleshooting recommendations?   Thanks in advance!</p>
]]></description><link>https://forum.recalbox.com/post/21816</link><guid isPermaLink="true">https://forum.recalbox.com/post/21816</guid><dc:creator><![CDATA[esmith13]]></dc:creator><pubDate>Wed, 01 Jun 2016 16:52:04 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble using GASIA controller REcalbox 4.0 and RASPBERRY PI3 on Mon, 09 May 2016 21:46:40 GMT]]></title><description><![CDATA[<p dir="auto">Hi, Did you read this <a href="https://github.com/recalbox/recalbox-os/wiki/Manual-%28EN%29#ps3controllers" rel="nofollow ugc">article</a> ? To use gasia controllers, you have to change driver used by recalbox then associate it.</p>
]]></description><link>https://forum.recalbox.com/post/20957</link><guid isPermaLink="true">https://forum.recalbox.com/post/20957</guid><dc:creator><![CDATA[nosfay]]></dc:creator><pubDate>Mon, 09 May 2016 21:46:40 GMT</pubDate></item></channel></rss>
