<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PS 3 Clone Controller isn&#x27;t working. (Gasia)]]></title><description><![CDATA[<p dir="auto">Hello, I bought a PS 3 Clone Controller, then i plugged it in the Raspberry Pi for 10 Seconds. After that i pressed the PS Home Button, but nothing happens. My Bluetooth Dongle is in Compatibility List as: <strong>CSL-V4.0 nano Bluetooth Adapter</strong> And i already changed the PS3 Controller Driver in recalbox.config to **gasia **which is the manufacturer of my Controller. I found that out with the <strong>dmesg</strong> Command via SSH. I've tried to manually pair the Controllers with <strong>hcitool scan</strong> also. It found my Smartphone via Bluetooth but not my Controller.   After all that  the Controller still don't work. I hope someone can help me with this problem. thanks.</p>
]]></description><link>https://forum.recalbox.com/topic/2208/ps-3-clone-controller-isn-t-working-gasia</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Mar 2026 08:12:08 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/2208.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Feb 2016 19:20:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PS 3 Clone Controller isn&#x27;t working. (Gasia) on Thu, 03 Mar 2016 06:50:44 GMT]]></title><description><![CDATA[<p dir="auto">As it turns out, they still have to be re paired every time I power off the recalbox or the controllers go to sleep from inactivity. Frustrating as hell!</p>
]]></description><link>https://forum.recalbox.com/post/17010</link><guid isPermaLink="true">https://forum.recalbox.com/post/17010</guid><dc:creator><![CDATA[dcollette1981]]></dc:creator><pubDate>Thu, 03 Mar 2016 06:50:44 GMT</pubDate></item><item><title><![CDATA[Reply to PS 3 Clone Controller isn&#x27;t working. (Gasia) on Wed, 02 Mar 2016 18:27:51 GMT]]></title><description><![CDATA[<p dir="auto">It looks like that they are completely the same as mine.</p>
]]></description><link>https://forum.recalbox.com/post/16973</link><guid isPermaLink="true">https://forum.recalbox.com/post/16973</guid><dc:creator><![CDATA[farbkasten]]></dc:creator><pubDate>Wed, 02 Mar 2016 18:27:51 GMT</pubDate></item><item><title><![CDATA[Reply to PS 3 Clone Controller isn&#x27;t working. (Gasia) on Wed, 02 Mar 2016 17:49:07 GMT]]></title><description><![CDATA[<p dir="auto">Turns out it was just this one set of controllers, they're geisa controllers called "hotso" I just got 4 more sets in the mail, and they all work with the recalbox. ill post pics in a while. but heres a link to the working ones. <a href="http://www.amazon.com/HOTSO-Wireless-Bluetooth-Game-Controller/dp/B00XKXZCFM/ref=sr_1_3?ie=UTF8&amp;qid=1456937296&amp;sr=8-3&amp;keywords=hotso+ps3+controller" rel="nofollow ugc">http://www.amazon.com/HOTSO-Wireless-Bluetooth-Game-Controller/dp/B00XKXZCFM/ref=sr_1_3?ie=UTF8&amp;qid=1456937296&amp;sr=8-3&amp;keywords=hotso+ps3+controller</a></p>
]]></description><link>https://forum.recalbox.com/post/16971</link><guid isPermaLink="true">https://forum.recalbox.com/post/16971</guid><dc:creator><![CDATA[dcollette1981]]></dc:creator><pubDate>Wed, 02 Mar 2016 17:49:07 GMT</pubDate></item><item><title><![CDATA[Reply to PS 3 Clone Controller isn&#x27;t working. (Gasia) on Wed, 02 Mar 2016 17:31:08 GMT]]></title><description><![CDATA[<p dir="auto">I tried it with both versions and all driver options. When i plug the cable in and press Home Button P1-Led is blinking. If i unplug it all four leds are blinking but they didn't connect.</p>
]]></description><link>https://forum.recalbox.com/post/16967</link><guid isPermaLink="true">https://forum.recalbox.com/post/16967</guid><dc:creator><![CDATA[farbkasten]]></dc:creator><pubDate>Wed, 02 Mar 2016 17:31:08 GMT</pubDate></item><item><title><![CDATA[Reply to PS 3 Clone Controller isn&#x27;t working. (Gasia) on Wed, 02 Mar 2016 17:25:40 GMT]]></title><description><![CDATA[<p dir="auto">Which Controllers do you have? These are mine: <a href="http://www.directupload.net" rel="nofollow ugc"><img src="http://fs5.directupload.net/images/160302/9sgqr2qe.jpg" alt class=" img-responsive img-markdown" /></a> <a href="http://www.directupload.net" rel="nofollow ugc"><img src="http://fs5.directupload.net/images/160302/53mar8pn.jpg" alt class=" img-responsive img-markdown" /></a> <a href="http://www.directupload.net" rel="nofollow ugc"><img src="http://fs5.directupload.net/images/160302/3z7pemhz.jpg" alt class=" img-responsive img-markdown" /></a></p>
]]></description><link>https://forum.recalbox.com/post/16965</link><guid isPermaLink="true">https://forum.recalbox.com/post/16965</guid><dc:creator><![CDATA[farbkasten]]></dc:creator><pubDate>Wed, 02 Mar 2016 17:25:40 GMT</pubDate></item><item><title><![CDATA[Reply to PS 3 Clone Controller isn&#x27;t working. (Gasia) on Wed, 02 Mar 2016 17:06:34 GMT]]></title><description><![CDATA[<p dir="auto">which recalbox version are you using ? in recalbox 3.3.0 beta 17, you must select gasia driver in your recalbox.conf file. but in recalbox 4.0.0 beta1, you must select official driver in your recalbox.conf file. The official driver work both with official and gasia gamepads.</p>
]]></description><link>https://forum.recalbox.com/post/16957</link><guid isPermaLink="true">https://forum.recalbox.com/post/16957</guid><dc:creator><![CDATA[rockaddicted]]></dc:creator><pubDate>Wed, 02 Mar 2016 17:06:34 GMT</pubDate></item><item><title><![CDATA[Reply to PS 3 Clone Controller isn&#x27;t working. (Gasia) on Tue, 01 Mar 2016 21:29:56 GMT]]></title><description><![CDATA[<p dir="auto">Same problem here, although I did get them to connect once, but the moment the recalbox was restarted, or my controllers turned off, they would be unpaired again. Anyone?? Really need help here, I tried everything that farbkasten did as well.</p>
]]></description><link>https://forum.recalbox.com/post/16900</link><guid isPermaLink="true">https://forum.recalbox.com/post/16900</guid><dc:creator><![CDATA[dcollette1981]]></dc:creator><pubDate>Tue, 01 Mar 2016 21:29:56 GMT</pubDate></item><item><title><![CDATA[Reply to PS 3 Clone Controller isn&#x27;t working. (Gasia) on Tue, 01 Mar 2016 20:13:24 GMT]]></title><description><![CDATA[<p dir="auto">Nobody got a solution?</p>
]]></description><link>https://forum.recalbox.com/post/16886</link><guid isPermaLink="true">https://forum.recalbox.com/post/16886</guid><dc:creator><![CDATA[farbkasten]]></dc:creator><pubDate>Tue, 01 Mar 2016 20:13:24 GMT</pubDate></item></channel></rss>
