Raspberry Pi 4
The Recalbox Team.
Official recalbox 4.0.0 beta thread
  • Staff
    Team
    This is the official thread for the beta of recalboxOS 4.0.0. Remember to post your issues on github (https://github.com/recalbox/recalbox-os/issues)
  • Good job 😉
  • Banned
    Hi guys I suppose many wiki pages will become obsolete with 4.0.0 (just the new read only system partition will lead to some trouble for custom configuration ?)   Isn't this exactly the right time to start a new, separate wiki with a better wiki system (categorization of pages and automatic tagging of new or recently modified pages woul be great, transparent localiaation too)   Otherwise obsolete pages will keep appearing side to side with the new ones, leading to confusion
  • Amazing work guys. I'm starting my build now and have a Mame question I see that in 4.0.0 it is using LR-Mame2003 as the default which uses romset version : 0.78 Is there any reason to go for the FBA 0.2.97.37 instead? It's amazing home complex this mame stuff can be. Thanks.
  • Revisor
    Great ... a lot of useful and interesting  new functionalities. Thank you !!! I've just installed it on my "test" SD card and started to have a look. Just a question for now: Is it normal that A and B buttons behavior are inverted (a for back and b for select now) ?
  • Bonjour, Je possĂšde des manette NES30, j'arrive Ă  les associĂ© via Bluetooth (je vois la mac adresse, m'affiche manette associĂ©) mais je ne sais pas configurer les boutons dans Emulstation. En usb la manette fonctionne et  avec recalbox 3 beta 17 aussi. Par contre comme dis plus haut par Laurent, le bouton A et B sont inversĂ©s dans Emulstation. L'installation m'a donnĂ© envie de tester un peu plus la bĂȘte  et les nouvelles fonctionalitĂ©s 🙂
  • Bonjour. Je viens d'essayer de me loguer sur le "module" retro achievement, mais lorsque je veux rentrer mon pseudo, impossible d'entrĂ©e une lettre dans le champs prĂ©vu. J'ai testĂ© avec un clavier sans fil et un filaire. MĂȘme rĂ©sultat.
  • Thank you! I can't wait to try this update. Does it need a fresh install on an SD Card, or should the Auto Update work? At the moment I'm getting a 'No Update Available' message. Thank you again!
  • En attendant d'avoir une rĂ©ponse, tu peux modifier le fichier recalbox.conf depuis recalbox manager en tapant l'adresse ip du rpi dans ton navigateur internet.
  • J'ai repassĂ© recalbox en anglais et ça a fonctionnĂ©.
  • Comme Steve, je n'ai pas de mise a jour disponible depuis le menu principal ?
  • Bonjour Ă  tous. D'abord super boulot cette nouvelle version ! NĂ©anmoins j'ai le mĂȘme souci que JĂ©rĂ©my mais avec une 8BitDo NES30 Pro en bluetooth. Connexion / appairage ok (mode Normal ou Joystick) mais pas de dĂ©tection lors de la configuration. En USB ça fonctionne nickel. Si quelqu'un Ă  une piste... Je suis preneur 🙂 Merci !
  • Banned
    Bravo pour la mise à jour, bon j'ai déjà detecté pas mal de problÚmes : - ES est beaucoup plus lent qu'avant dans les menus chez moi - A et B sont inversés dans ES par rapport à avant et deviennent incohérents avec les libellés en bas
  • So, first of all; congrats for the awesome work made here. The amount of changes from the 3.3/17 is really huge. All the work here is pretty impressive. I have few problems with the version 4.0, one huge and the others... well, not a lot; but quite annoying.  Since looks that the upgrade from 3.3 to 4.0 has to be manual; i made a backup (just in case), format the sd and a clean install of the 4.0. After re-put inside all the games; and all the savegames (a lot of files) in its "/save/especific-system" new location; i realized that some of them doesn't work anymore. 😧 Savestates don't either. (Example, Legend of zelda the minish cap, GBA) The PcengineCD games doesn't work too, with the same files working flawlessly in the 3.3 And, since "thegamedatabase.net" is down and there's a lot of roms to manually scrape; tried to paste my downloaded_images and gamelists folders in the new version, but i can't find it. Where is the location?
  • Hello and thank you for all the efort on your work. Im the administrator of the recalbox sub reddit on Reddit, and people noticed some things that i want to ask you Maybe the question that youll had to answer more times It is normal that in emulationstation A and B buttons are mixed? Next one: a lot of directories changed, how is the method to add individual inputs for each emulator? I tried the old one but doesnt work (im a little noob at this) And finally, how to make save files work? Thank you for your time
  • Banned
    @Dragda For scrape : gamelist.xml are now located in roms folder, as the name of the folders are the same you can copy everything from the old gamelist directory to the rom directory (fba libretro seems to cause trouble but it's likely just a name change) images are to be put into /recalbox/share/system/.emulationstation/downloaded_images
  • Banned
    • Plus aucun jeu neo geo ne marche dans fba_libretro - ou est passĂ© le fichier es_systems.cfg ? - comment modifier le config.txt pour l'overscan sur la partition en lecture seule ?
  • @Voljega : pour modifier le fichier config.txt contenu dans la partition /boot : mount -o remount,rw /boot Accessoirement que donne une recherche "find -name es_systems.cfg" ?
  • Bon bah je sens que je vais attendre finalement avant de faire cette mise Ă  jour ....
  • Banned
    @Denis   Merci mais du coup l'activation de l'overscan dans le menu marche quand méme ou pas ?
77.2k
19.4k
143.9k
