<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[(Solved)SegaCD Not Working]]></title><description><![CDATA[<p dir="auto">First off, let me just say thanks and well done. This is an awesome project. When downloading the roms from planetemu for SegaCD as recommended in the segacd rom folder, I can't get them to work. The forums all talk about needing to use bin/cue but the roms downloaded from planetemu aren't that format. I'm using a mac to do all this, but don't know if that's the issue and have been transferring them to recalbox through finder over the network. Is there something I need to do to convert them? Any thoughts?</p>
]]></description><link>https://forum.recalbox.com/topic/2083/solved-segacd-not-working</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 19:20:19 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/2083.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Feb 2016 01:09:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to (Solved)SegaCD Not Working on Fri, 27 May 2016 13:10:03 GMT]]></title><description><![CDATA[<p dir="auto">Read the wiki on Github, it's pretty self-explanatory</p>
]]></description><link>https://forum.recalbox.com/post/21645</link><guid isPermaLink="true">https://forum.recalbox.com/post/21645</guid><dc:creator><![CDATA[voljega]]></dc:creator><pubDate>Fri, 27 May 2016 13:10:03 GMT</pubDate></item><item><title><![CDATA[Reply to (Solved)SegaCD Not Working on Fri, 27 May 2016 12:23:42 GMT]]></title><description><![CDATA[<p dir="auto">Im having the same issue. Ive downloaded multiple bios files but non work.. What folder do they go in and what bios files do i use?</p>
]]></description><link>https://forum.recalbox.com/post/21641</link><guid isPermaLink="true">https://forum.recalbox.com/post/21641</guid><dc:creator><![CDATA[jonjon1977]]></dc:creator><pubDate>Fri, 27 May 2016 12:23:42 GMT</pubDate></item><item><title><![CDATA[Reply to (Solved)SegaCD Not Working on Wed, 10 Feb 2016 05:30:12 GMT]]></title><description><![CDATA[<p dir="auto">Problem solved. I was missing the BIOS files.</p>
]]></description><link>https://forum.recalbox.com/post/15956</link><guid isPermaLink="true">https://forum.recalbox.com/post/15956</guid><dc:creator><![CDATA[fouroh3]]></dc:creator><pubDate>Wed, 10 Feb 2016 05:30:12 GMT</pubDate></item><item><title><![CDATA[Reply to (Solved)SegaCD Not Working on Tue, 09 Feb 2016 06:41:57 GMT]]></title><description><![CDATA[<p dir="auto">No. Once I unzip the file, I get an .iso, 35 .wav files and then a .cue file.</p>
]]></description><link>https://forum.recalbox.com/post/15918</link><guid isPermaLink="true">https://forum.recalbox.com/post/15918</guid><dc:creator><![CDATA[fouroh3]]></dc:creator><pubDate>Tue, 09 Feb 2016 06:41:57 GMT</pubDate></item><item><title><![CDATA[Reply to (Solved)SegaCD Not Working on Tue, 09 Feb 2016 04:44:58 GMT]]></title><description><![CDATA[<p dir="auto">nano /etc/emulationstation/es_systems.cfg scroll down to segacd and add the file extension to the list. Prob .img right?</p>
]]></description><link>https://forum.recalbox.com/post/15917</link><guid isPermaLink="true">https://forum.recalbox.com/post/15917</guid><dc:creator><![CDATA[kryptalivian]]></dc:creator><pubDate>Tue, 09 Feb 2016 04:44:58 GMT</pubDate></item></channel></rss>
