<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clearing the Last Played&#x2F;Times Played count]]></title><description><![CDATA[<p dir="auto">Hi all. Congrats on 6.1.1. It is awesome!</p>
<p dir="auto">Could someone recommend the best way to clear the last played and times played count from gamelists please? I thought I might be able to use a text editor but there are so many lines it would take ages! Is there an easier way to do this? Many thanks.</p>
]]></description><link>https://forum.recalbox.com/topic/19842/clearing-the-last-played-times-played-count</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 07:52:06 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/19842.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Jan 2020 12:44:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clearing the Last Played&#x2F;Times Played count on Sun, 19 Jan 2020 17:18:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/37208">@Lumpy</a> . If you are not worried to use python 2, you can use my little project on : <a href="https://github.com/nordicpower/gamelistpower/blob/master/gamelist_change_attr.py" rel="nofollow ugc">https://github.com/nordicpower/gamelistpower/blob/master/gamelist_change_attr.py</a></p>
<p dir="auto">You can this syntax : gamelist_change_attr.py remove_playinfo &lt;path_of_your_file&gt;</p>
]]></description><link>https://forum.recalbox.com/post/142752</link><guid isPermaLink="true">https://forum.recalbox.com/post/142752</guid><dc:creator><![CDATA[nordicpower]]></dc:creator><pubDate>Sun, 19 Jan 2020 17:18:10 GMT</pubDate></item><item><title><![CDATA[Reply to Clearing the Last Played&#x2F;Times Played count on Sat, 18 Jan 2020 14:03:33 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, it would need to be Linux based or at least compatible with WINE. I don't use Windows. Thank you for the suggestion though. <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":-)" alt="🙂" /></p>
]]></description><link>https://forum.recalbox.com/post/142707</link><guid isPermaLink="true">https://forum.recalbox.com/post/142707</guid><dc:creator><![CDATA[Lumpy]]></dc:creator><pubDate>Sat, 18 Jan 2020 14:03:33 GMT</pubDate></item><item><title><![CDATA[Reply to Clearing the Last Played&#x2F;Times Played count on Sat, 18 Jan 2020 12:38:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/37208">@lumpy</a><br />
With bit late, but you could do that with ARRM : <a href="http://jujuvincebros.fr/wiki/arrm/doku.php?id=delete_metadata_en" rel="nofollow ugc">http://jujuvincebros.fr/wiki/arrm/doku.php?id=delete_metadata_en</a><br />
Make a back up of your gamelist.xml before you test.</p>
]]></description><link>https://forum.recalbox.com/post/142704</link><guid isPermaLink="true">https://forum.recalbox.com/post/142704</guid><dc:creator><![CDATA[nexusone13]]></dc:creator><pubDate>Sat, 18 Jan 2020 12:38:59 GMT</pubDate></item><item><title><![CDATA[Reply to Clearing the Last Played&#x2F;Times Played count on Fri, 17 Jan 2020 18:44:28 GMT]]></title><description><![CDATA[<p dir="auto">Figured it out. Helps if you know how to use a text editor. Lol.</p>
]]></description><link>https://forum.recalbox.com/post/142677</link><guid isPermaLink="true">https://forum.recalbox.com/post/142677</guid><dc:creator><![CDATA[Lumpy]]></dc:creator><pubDate>Fri, 17 Jan 2020 18:44:28 GMT</pubDate></item></channel></rss>
