<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Retro-bit bluetooth 8button sega genesis controller not transitioning to retroarch]]></title><description><![CDATA[<p dir="auto">Hi! Thanks for the development work to make recalbox. Its been great. Ive been using xbox360, ps3 and wired xbox360 controllers which work awesome. I much prefer the recalbox interface and layout to retropie. I just started having issues when I tried to pair this [bluetooth retrobit genesis controller](Retro-Bit Official Sega Genesis Bluetooth Controller 8-Button Arcade Pad for Android, PC, Mac, Steam - Clear Blue <a href="https://www.amazon.com/dp/B07XV8LN94/ref=cm_sw_r_cp_apa_i_Spd8DbWG4MMWM" rel="nofollow ugc">https://www.amazon.com/dp/B07XV8LN94/ref=cm_sw_r_cp_apa_i_Spd8DbWG4MMWM</a>)</p>
<p dir="auto">I was having pairing and configuration  issues in emulation station for a few days and finally got it to pair and configure by adding a udev rule. It works smoothly in emulation station.</p>
<p dir="auto">Now it appears to causing issues handing off to  configgen or retroarch.  When i choose a genesis game (SF2) from emulation station, the screen goes black and stays black until i turn  off my retrobit controller. The game will load. I then turn on the retrobit controller and it pairs but the button config is wrong and most of the buttons dont work. The home/hotkey+A also doesnt do anything. If i plug in a 2nd wired controller, i can enter the retroarch menu (hotkey+A) and correct the button mapping for the retrobit controller but it seems to have no effect and half the buttons dont work at all.</p>
<p dir="auto">Any hints on how to fix the blackscreen/retroarch not starting issue (w/o turning the controller on and off) and how to correct the button mapping? Any help is appreciated.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.recalbox.com/topic/19605/retro-bit-bluetooth-8button-sega-genesis-controller-not-transitioning-to-retroarch</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 05:55:34 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/19605.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Dec 2019 00:08:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Retro-bit bluetooth 8button sega genesis controller not transitioning to retroarch on Wed, 11 Dec 2019 00:20:09 GMT]]></title><description><![CDATA[<p dir="auto">Forgot this. Using RPI3b and recalbox 6.1.1</p>
]]></description><link>https://forum.recalbox.com/post/141336</link><guid isPermaLink="true">https://forum.recalbox.com/post/141336</guid><dc:creator><![CDATA[dabiz]]></dc:creator><pubDate>Wed, 11 Dec 2019 00:20:09 GMT</pubDate></item></channel></rss>
