<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[6.1 update dont overwrite files]]></title><description><![CDATA[<p dir="auto">hi,<br />
the update form 6.0 to 6.1 dont overwrite the files that have the same names.<br />
This is a bit prob if the files change (for example readme.txt bios files), u dont have the last version and cannot check them (only by browser u can check them)<br />
I dont know if there are other changes that need the "last file version".<br />
maybe on update overwrite some folders and not other (configurations).</p>
<p dir="auto">tks</p>
]]></description><link>https://forum.recalbox.com/topic/18784/6-1-update-dont-overwrite-files</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 16:22:37 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/18784.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Sep 2019 08:58:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 6.1 update dont overwrite files on Mon, 04 Nov 2019 20:00:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/3100">@oyyodams</a> tks for reply,<br />
we are talking about readme.txt files, or bios.txt.<br />
its no sense because these files have all infos, and the infos changes with the update.<br />
i understand, roms, or bios files, but txt?!? if txt file change need to update them.</p>
]]></description><link>https://forum.recalbox.com/post/139284</link><guid isPermaLink="true">https://forum.recalbox.com/post/139284</guid><dc:creator><![CDATA[gothrek]]></dc:creator><pubDate>Mon, 04 Nov 2019 20:00:50 GMT</pubDate></item><item><title><![CDATA[Reply to 6.1 update dont overwrite files on Sat, 02 Nov 2019 05:51:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/14643">@gothrek</a> files in your personnal share partition are never overwritten upon update.</p>
]]></description><link>https://forum.recalbox.com/post/139117</link><guid isPermaLink="true">https://forum.recalbox.com/post/139117</guid><dc:creator><![CDATA[OyyoDams]]></dc:creator><pubDate>Sat, 02 Nov 2019 05:51:43 GMT</pubDate></item><item><title><![CDATA[Reply to 6.1 update dont overwrite files on Fri, 01 Nov 2019 16:45:11 GMT]]></title><description><![CDATA[<p dir="auto">someone found the same prob?</p>
]]></description><link>https://forum.recalbox.com/post/139097</link><guid isPermaLink="true">https://forum.recalbox.com/post/139097</guid><dc:creator><![CDATA[gothrek]]></dc:creator><pubDate>Fri, 01 Nov 2019 16:45:11 GMT</pubDate></item></channel></rss>
