<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Recalbox black screen on startup]]></title><description><![CDATA[<p dir="auto">I was adding a few games and bios files over winscp and now recalbox won't boot. The screen remains blank and the menu music plays but I cannot select anything..  Has anyone had a similar issue? Not sure what I have done to break it. *This is what i get when trying to get into my NES folder. I have a .zip file that I can't seem to delete 720?.zip &lt;h1&gt;UnicodeDecodeError at /systems/roms/nes/&lt;/h1&gt; &lt;pre class="exception_value"&gt;'ascii' codec can't decode byte 0xb0 in position 4: ordinal not in range(128) &lt;table class="meta"&gt; &lt;tbody&gt; &lt;tr&gt; &lt;th&gt;Request Method:&lt;/th&gt; &lt;td&gt;GET&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Request URL:&lt;/th&gt; &lt;td&gt;<a href="http://192.168.1.121/systems/roms/nes/" rel="nofollow ugc">http://192.168.1.121/systems/roms/nes/</a>&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Django Version:&lt;/th&gt; &lt;td&gt;1.8.5&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Exception Type:&lt;/th&gt; &lt;td&gt;UnicodeDecodeError&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Exception Value:&lt;/th&gt; &lt;td&gt;</p>
<p dir="auto">&lt;pre&gt;'ascii' codec can't decode byte 0xb0 in position 4: ordinal not in range(128)&lt;/pre&gt;</p>
<p dir="auto">&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Exception Location:&lt;/th&gt; &lt;td&gt;/usr/recalbox-manager/project/manager_frontend/views/roms.py in get_rom_choices, line 52&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Python Executable:&lt;/th&gt; &lt;td&gt;/usr/bin/python&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Python Version:&lt;/th&gt; &lt;td&gt;2.7.10&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Python Path:&lt;/th&gt; &lt;td&gt;</p>
<p dir="auto">&lt;pre&gt;['/usr/recalbox-manager',<br />
'/usr/lib/python27.zip',<br />
'/usr/lib/python2.7',<br />
'/usr/lib/python2.7/plat-linux2',<br />
'/usr/lib/python2.7/lib-tk',<br />
'/usr/lib/python2.7/lib-old',<br />
'/usr/lib/python2.7/lib-dynload',<br />
'/usr/lib/python2.7/site-packages']&lt;/pre&gt;</p>
<p dir="auto">&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Server time:&lt;/th&gt; &lt;td&gt;Sun, 10 Jan 2016 00:26:15 +0100&lt;/td&gt; &lt;/tr&gt; &lt;/tbody&gt; &lt;/table&gt;</p>
]]></description><link>https://forum.recalbox.com/topic/1872/recalbox-black-screen-on-startup</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 15:03:54 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/1872.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Jan 2016 20:25:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Recalbox black screen on startup on Fri, 19 Feb 2016 21:01:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys, I ran into this problem today and I think I found out why it's happening. The 720?.zip file is the rom file for 720˚, which has a character in it which recalbox does not support. I was able to get my system booting as normal by removing the ? character from the filename.</p>
]]></description><link>https://forum.recalbox.com/post/16252</link><guid isPermaLink="true">https://forum.recalbox.com/post/16252</guid><dc:creator><![CDATA[michael-fryer]]></dc:creator><pubDate>Fri, 19 Feb 2016 21:01:58 GMT</pubDate></item><item><title><![CDATA[Reply to Recalbox black screen on startup on Mon, 25 Jan 2016 22:18:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi, A quick update to this. It seems to work when I copy over only one or 2 ROMs, but not when I copy over 700+. Perhaps this is where the 720?.nes file comes from? Not sure. Regards, Tom</p>
]]></description><link>https://forum.recalbox.com/post/15546</link><guid isPermaLink="true">https://forum.recalbox.com/post/15546</guid><dc:creator><![CDATA[flooreus]]></dc:creator><pubDate>Mon, 25 Jan 2016 22:18:28 GMT</pubDate></item><item><title><![CDATA[Reply to Recalbox black screen on startup on Mon, 25 Jan 2016 14:56:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/79071">@retroboy</a> I don't suppose you have any more suggestions as to what might be going on here?</p>
]]></description><link>https://forum.recalbox.com/post/15525</link><guid isPermaLink="true">https://forum.recalbox.com/post/15525</guid><dc:creator><![CDATA[flooreus]]></dc:creator><pubDate>Mon, 25 Jan 2016 14:56:09 GMT</pubDate></item><item><title><![CDATA[Reply to Recalbox black screen on startup on Sun, 24 Jan 2016 22:57:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi I'm having the exact same issue. The recalbox Pi works fine playing ROMs, configuring Kodi and playing around with settings, but then I transferred a bunch of NES ROMs, rebooted the Pi and I got a blank screen with background music. It wouldn't recognise any input from my controller, so I rebooted but no dice. I removed all the NES ROMs but it made no difference. So, I rebuil the Pi and it was all fine, until again I transferred the NES ROMs over and it did the same thing. I removed the files but there was a '720?.nes' file there, which won't be deleted. I went to the web front-end and it displays an error about the 720?.nes file: &lt;table class="meta"&gt; &lt;tbody&gt; &lt;tr&gt; &lt;th&gt;Request Method:&lt;/th&gt; &lt;td&gt;GET&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Request URL:&lt;/th&gt; &lt;td&gt;<a href="http://10.10.75.6/systems/roms/nes/" rel="nofollow ugc">http://10.10.75.6/systems/roms/nes/</a>&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Django Version:&lt;/th&gt; &lt;td&gt;1.8.5&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Exception Type:&lt;/th&gt; &lt;td&gt;UnicodeDecodeError&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Exception Value:&lt;/th&gt; &lt;td&gt;</p>
<p dir="auto">&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Server time:&lt;/th&gt; &lt;td&gt;Sun, 24 Jan 2016 22:40:00 +0100&lt;/td&gt; &lt;/tr&gt; &lt;/tbody&gt; &lt;/table&gt;   Any ideas what might be going on here?! The complete web page error is attached. Regards, Tom</p>
]]></description><link>https://forum.recalbox.com/post/15514</link><guid isPermaLink="true">https://forum.recalbox.com/post/15514</guid><dc:creator><![CDATA[flooreus]]></dc:creator><pubDate>Sun, 24 Jan 2016 22:57:07 GMT</pubDate></item><item><title><![CDATA[Reply to Recalbox black screen on startup on Sun, 10 Jan 2016 21:58:25 GMT]]></title><description><![CDATA[<p dir="auto">You cannot delete it in the network shares ?</p>
]]></description><link>https://forum.recalbox.com/post/15009</link><guid isPermaLink="true">https://forum.recalbox.com/post/15009</guid><dc:creator><![CDATA[digitaLumberjack]]></dc:creator><pubDate>Sun, 10 Jan 2016 21:58:25 GMT</pubDate></item><item><title><![CDATA[Reply to Recalbox black screen on startup on Sun, 10 Jan 2016 18:39:10 GMT]]></title><description><![CDATA[<p dir="auto">There appears to be a nes game that I can't delete, it's called 720?.zip I think that's what's causing the issue. No idea how to remove it... Do you think if I reformat my sd card and this will fix everything? I'm sure it would but I'm worried because when I insert my sd into computer it says it only has a 400mb memory instead of 64gb.</p>
]]></description><link>https://forum.recalbox.com/post/15005</link><guid isPermaLink="true">https://forum.recalbox.com/post/15005</guid><dc:creator><![CDATA[Anonpebbles]]></dc:creator><pubDate>Sun, 10 Jan 2016 18:39:10 GMT</pubDate></item><item><title><![CDATA[Reply to Recalbox black screen on startup on Sun, 10 Jan 2016 14:51:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi, did you switch to the ZOID theme before adding your roms ? How many different system did you put rom for ? try to find the rom folder directly in your windows network and choose nes system and remove all the roms. <a href="https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#vi---network-features" rel="nofollow ugc">https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#vi---network-features</a></p>
]]></description><link>https://forum.recalbox.com/post/14979</link><guid isPermaLink="true">https://forum.recalbox.com/post/14979</guid><dc:creator><![CDATA[digitaLumberjack]]></dc:creator><pubDate>Sun, 10 Jan 2016 14:51:57 GMT</pubDate></item><item><title><![CDATA[Reply to Recalbox black screen on startup on Sun, 10 Jan 2016 00:15:05 GMT]]></title><description><![CDATA[<p dir="auto">just another update, i get an error when trying to edit my .cfg file. has a message that says "You're seeing this error because you have <code>DEBUG = True</code> in your Django settings file. Change that to <code>False</code>, and Django will display a standard page generated by the handler for this status code." Where can i find this folder? Most of my folders I can add/remove stuff but for some reason my nes one is read only and so is the cfg apparently..</p>
]]></description><link>https://forum.recalbox.com/post/14968</link><guid isPermaLink="true">https://forum.recalbox.com/post/14968</guid><dc:creator><![CDATA[Anonpebbles]]></dc:creator><pubDate>Sun, 10 Jan 2016 00:15:05 GMT</pubDate></item><item><title><![CDATA[Reply to Recalbox black screen on startup on Sat, 09 Jan 2016 20:28:05 GMT]]></title><description><![CDATA[<p dir="auto">I have just tried to access my roms via the recalbox menu (last ones I added before the break were NES) and I got this error message: &lt;h1&gt;UnicodeDecodeError at /systems/roms/nes/&lt;/h1&gt; &lt;pre class="exception_value"&gt;'ascii' codec can't decode byte 0xb0 in position 4: ordinal not in range(128) &lt;table class="meta"&gt; &lt;tbody&gt; &lt;tr&gt; &lt;th&gt;Request Method:&lt;/th&gt; &lt;td&gt;GET&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Request URL:&lt;/th&gt; &lt;td&gt;<a href="http://192.168.1.121/systems/roms/nes/" rel="nofollow ugc">http://192.168.1.121/systems/roms/nes/</a>&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Django Version:&lt;/th&gt; &lt;td&gt;1.8.5&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Exception Type:&lt;/th&gt; &lt;td&gt;UnicodeDecodeError&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Exception Value:&lt;/th&gt; &lt;td&gt;</p>
<p dir="auto">&lt;/td&gt; &lt;/tr&gt; &lt;tr&gt; &lt;th&gt;Server time:&lt;/th&gt; &lt;td&gt;Sat, 9 Jan 2016 20:26:03 +0100     I also cannot remove these files via winscp as it says they are read only. Any ideas?&lt;/td&gt; &lt;/tr&gt; &lt;/tbody&gt; &lt;/table&gt;</p>
]]></description><link>https://forum.recalbox.com/post/14964</link><guid isPermaLink="true">https://forum.recalbox.com/post/14964</guid><dc:creator><![CDATA[Anonpebbles]]></dc:creator><pubDate>Sat, 09 Jan 2016 20:28:05 GMT</pubDate></item></channel></rss>
