Raspberry Pi 4
The Recalbox Team.
[GPi Case] Recalbox 6.1 Beta 3 - New Public Beta!
  • @oyyodams OK cool! Can't wait to see what it looks like. Read the Changelog/Release Notes and it's looking awesome. Keep up the good work. Appreciate the fast reply, you guys are on it! Have a great a day.
  • Staff
    Moderator
    Team
    Beta 3 available in the original post.
  • Why am I having issues with GBA? This is a fresh install of Beta 3.
    Video.
    Video Via Mega
  • Staff
    Team
    Moderator
    Translator
    @dark_hunter you’d need to share more info... are you having sound problems? Are those sound problems only on a specific game or everywhere? What core are you using? What core where you using before, the same? Defaults might change, so it is important to be specific. Have you tried with other cores? Same behavior?
  • D-pad not working on the 6.1 beta 3. Fresh install.
    troubleshootings files
  • Staff
    Team
    Moderator
    Translator
    @alvaro-larsen read at the bottom of: http://download.retroflag.com/
    Q: Why No DPad and buttons work?
    1. The short usb cable in the cartridge connection issue, please assemble the short usb cable again.
  • @paradadf said in [GPi Case] Recalbox 6.1 Beta 3 - New Public Beta!:
    Seems to only affect the sound and one core which is GBA, not using anything else but what was supplied to me.
  • Staff
    Team
    Moderator
    Translator
    @dark_hunter if you press START on top of the gamelist you can edit the emulator and core to use others, for example gpsp. It needs bios though, that was the reason it was removed from being the default for rpi0/1, although it should be the fastest (less accurate). Try different cores and compare games between cores to see what give’s you the best experience and share it here.
  • @paradadf selecting GPSP works.
  • bonjour j'ai vu qu'il fallais 2 dissipateurs de chaleur en cuivre Premium, par contre je ne trouve pas lesquel au meilleurs prix et a la bonne taille.
    qui aurait le lien amazon ou autre svp ?
  • Test de la beta 3... J'ai entendu dans le live que Crash Bandicoot tournait super bien sur l'emu PSX... Pour ma part le son est bizarre (crapouilleux, comme si on manquait de débit) et l'image est cantonné aux 2/3 supérieurs de l'écran. Y a-t-il une astuce qui m'échappe. Un bios bien précis à installer ?
  • Why is bluetooth disabeled on beta3 and can i enable it?
  • @wolfme not yeah you can enable it, I'm sure it's disabled for battery life in mind.
    I also would like to point out that the WebManager is not enabled out of the box and must be turned on via advanced settings.
  • @paradadf thanks, i tought that was the problem.
    but the real issue was that i got my gpi case D-pad into “Axis mode”.
    so the solution was getting the D-pad to “Hat mode”.
    D-pad "Hat mode":
    SELECT + D-PAD UP for 5 seconds. Device led will flash purple when done.
    D-pad “Axis mode”:
    SELECT + D-PAD LEFT for 5 seconds. Device led will flash purple when done.
  • Does anyone know of a way to disable the Recalbox ‘loading’ screen with Pac-Man? I’d prefer if it were just black! Thanks
  • Staff
    Moderator
    Team
    @sibobbbe said in [GPi Case] Recalbox 6.1 Beta 3 - New Public Beta!:
    Not possible.
  • @acris Oh that's a shame, but thanks appreciate the reply
  • Hello there, I've found 2 issues with the beta 3 :
    • NO snes game run with the default snesPi emulator, it tries loading and then goes back to the game selection screen, if I manually chose to change it to snes9x it works but it's slow, that's why I would like to use the specific snesPi emulator, any idea why it doesnt work ? Fresh install of the beta 3 on a new SD card, every other console work fine.
    • I've noticed some vertical lines on the grey Recalbox menu on the left of my screen, very visible in high contrast, but mainly with background in grey colors, nearly invisible in most games, except grey ones, is it a hardware issue? Anyone else noticed?
    Thanks guys!
  • I have an issue where sometimes, after simply adding some games via Finder (I'm on mac) it takes five minutes to boot, then boots into full Recalbox, not the GPI version.
    This has happened twice and seems totally random. Both times I've had to start from scratch with a new installation. Is anyone else having this issue? Any ideas? Thanks
  • @maldorhan I got snes games to run by switching to Snes9x then switching back to pisnes. Sometimes it took a couple of tries. Weird but it works
Join us on :
210
